Siste Blåskjermen å drepe.
Hei!
Sitter her med Vistax64 og prøver å bli kvitt min siste blåskjerm, men trenger litt hjelp. Ser det gjelder drivere, men så har eg no installert alle drivere up to date.
Any ideas?
takker på førhånd.
Klikk for å se/fjerne innholdet nedenfor
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: Settlers6.exe
TRAP_FRAME: fffff9803158e870 -- (.trap 0xfffff9803158e870)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffffa800397e010 rbx=fffff9803158e9e0 rcx=fffffa80051bc590
rdx=fffff9803158ea70 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800018a345b rsp=fffff9803158ea00 rbp=fffffa8003cdc000
r8=00000000abbc4f56 r9=fffff9803158eac0 r10=0000000000000000
r11=fffff9803158eb68 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe cy
nt!EtwpReserveTraceBuffer+0x17b:
fffff800`018a345b 084e8d or byte ptr [rsi-73h],cl ds:5000:ffffffff`ffffff8d=??
Resetting default scope
MISALIGNED_IP:
nt!EtwpReserveTraceBuffer+17b
LAST_CONTROL_TRANSFER: from fffff8000184d973 to fffff8000184dbd0
STACK_TEXT:
fffff980`3158e728 fffff800`0184d973 : 00000000`0000000a ffffffff`ffffffb5 00000000`0000000b 00000000`00000001 : nt!KeBugCheckEx
fffff980`3158e730 fffff800`0184c84b : 00000000`00000001 00000000`00000028 00000000`00000000 fffff800`01ce8e5c : nt!KiBugCheckDispatch+0x73
fffff980`3158e870 fffff800`018a345b : fffffa80`063a1010 fffff980`043440b3 fffffa80`05b25000 fffff980`041352e1 : nt!KiPageFault+0x20b
fffff980`3158ea00 fffff800`018ede69 : fffffa80`03cdc000 00000000`00000024 fffff980`3158eaa8 fffff980`3158eac0 : nt!EtwpReserveTraceBuffer+0x17b
fffff980`3158ea70 fffff800`018c69a9 : 00000000`20004000 00000000`00000000 fffffa80`00000002 fffff800`01ce8e5c : nt!EtwpLogKernelEvent+0x1b9
fffff980`3158eb10 fffff800`018c6a0f : fffffa80`04a0dc08 fffff980`3158eca0 fffffa80`04a0dc00 fffff800`018c6adf : nt!EtwTraceTimedEvent+0xd9
fffff980`3158eb70 fffff800`0184eb06 : fffffa80`04a0dc08 fffff980`3158eca0 fffffa80`04a0dc00 00000000`00000000 : nt!PerfInfoLogInterrupt+0x3f
fffff980`3158ebd0 fffff800`0184e8b2 : fffffa80`06beb590 00000000`00000004 00000000`00000000 fffff980`3158eca0 : nt!KiScanInterruptObjectList+0xc6
fffff980`3158ec20 00000000`08c4e38f : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiChainedDispatch+0x112
00000000`0017f1c8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x8c4e38f
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!EtwpReserveTraceBuffer+17b
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MODULE_NAME: hardware
FAILURE_BUCKET_ID: X64_IP_MISALIGNED
Followup: MachineOwner
Settlers6.exe hører til denne.
http://thesettlers.uk.ubi.com/home.php
Du for fjerne den så hjelper det nok.
Gå inn i forum og høre om andre kjører 64bit.
Nå er ikker 64bit en fullkommen på spill ennå.
Dette er noe du må regner med.
9575396[/snapback]
Men sliter egentlig med en god del spill, ikkje kun 1.
9576641[/snapback]
dette an komme av at du ikke har riktige drivere, eller spillet ikke tåler 64bit
du kan prøve å kjøre spillene i XP mode(er ikke sikker på om du kan kjøre de i 32bit mode)
9575396[/snapback]
kjørt XP64 siden januar. Aldri hatt noen problemer med spill. gamle og nye.
lønner seg nok å oppdatere drivere litt, uansett.
bios update på hk og gfkort er å anbefale.
