Boye Skrevet 20. oktober 2019 Rapporter Del Skrevet 20. oktober 2019 Lurer litt på det, realistisk sett: hvor stor er sjansen nå for at 20 tilfeldige privatpersoner i lille Norge sitter med en 3950X i 2019? Kan bli forsinkelse her også 8-( Lenke til kommentar
Theo343 Skrevet 20. oktober 2019 Rapporter Del Skrevet 20. oktober 2019 (endret) AMD accidentally leaks the Ryzen 7 3750X CPU https://www.notebookcheck.net/AMD-accidentally-leaks-the-Ryzen-7-3750X-CPU.439755.0.html Men 3950X frister.. The AMD Ryzen 9 3950X achieves even higher scores when combined with Asus’ Prime X570-P board and a whopping 64 GB of memory. This time, the single-core score recorded is 1,276 but even more noteworthy is the multi-core result of 15,401 points. The 16 cores of the Ryzen 9 3950X help it accrue a score that slots it in third place in Geekbench’s charts, with the 18 cores of the Intel Core i9-9980XE and i9-7980XE keeping the Matisse chip from the top. It’s important to keep in mind that AMD’s Ryzen 9 3950X is expected to cost US$749, whereas the two above-mentioned chips from Intel cost close to US$2,000 on Newegg. Desktop gamers could be in for an early Christmas present when the red team finally unleashes the Ryzen 9 3950X onto the market. Endret 20. oktober 2019 av Theo343 Lenke til kommentar
Nizzen Skrevet 20. oktober 2019 Rapporter Del Skrevet 20. oktober 2019 AMD accidentally leaks the Ryzen 7 3750X CPU https://www.notebookcheck.net/AMD-accidentally-leaks-the-Ryzen-7-3750X-CPU.439755.0.html Men 3950X frister.. Skrevet 31 minutter siden AMD accidentally leaks the Ryzen 7 3750X CPU https://www.notebook...U.439755.0.html Men 3950X frister.. Sitat The AMD Ryzen 9 3950X achieves even higher scores when combined with Asus’ Prime X570-P board and a whopping 64 GB of memory. This time, the single-core score recorded is 1,276 but even more noteworthy is the multi-core result of 15,401 points. The 16 cores of the Ryzen 9 3950X help it accrue a score that slots it in third place in Geekbench’s charts, with the 18 cores of the Intel Core i9-9980XE and i9-7980XE keeping the Matisse chip from the top. Sitat It’s important to keep in mind that AMD’s Ryzen 9 3950X is expected to cost US$749, whereas the two above-mentioned chips from Intel cost close to US$2,000 on Newegg. Desktop gamers could be in for an early Christmas present when the red team finally unleashes the Ryzen 9 3950X onto the market. De "glemte" å nevne at 10 serie 18 kjerneren til Intel som er ventet å koste under 1000$. Lenke til kommentar
Theo343 Skrevet 20. oktober 2019 Rapporter Del Skrevet 20. oktober 2019 Japp og 10920X er meget spennende Lenke til kommentar
FB.093090871808135 Skrevet 20. oktober 2019 Rapporter Del Skrevet 20. oktober 2019 Skrevet 31 minutter siden AMD accidentally leaks the Ryzen 7 3750X CPU https://www.notebook...U.439755.0.html Men 3950X frister.. Sitat Sitat De "glemte" å nevne at 10 serie 18 kjerneren til Intel som er ventet å koste under 1000$. Den har aldri kommet til å ha kostet under 1000$ hvis ikke Amd har hatt slike sterke cpu-er. Da har den kostet nærmere 2000$ Lenke til kommentar
Malvado Skrevet 20. oktober 2019 Rapporter Del Skrevet 20. oktober 2019 Tja, det finnes mennesker som har så mye penger at de ikke bryr seg om hva en slik cpu koster så lenge de kan vifte litt med den og vise til benchmarks. Så har du mannen i gata som faktisk får nytte av flere kjerner og som har forskjellige budsjett, det er det som er så bra med konkurranse og at vi har Amd vs Intel, dette fører til at prisene faller og at de faktisk må utvikle produktene sine for å kunne hele tiden konkurrere med hverandre. Uansett så viser lekasjene at vi kommer til å få flere cpu'er som er konkurransedyktige for de som ikke ønsker å bruke 5-8 tusen på en cpu men fortsatt trenger å oppgradere til noe bedre, greier Amd og Intel å komme med langt bedre cpu'er de neste årene har vi som elsker sånt mye å glede seg til... Lenke til kommentar
Theo343 Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 (endret) Hmm gikk glipp av at Intel 10980XE vill koste under 1000$. Det er en helt fantastisk utvikling!. Men må innrømme at siste rykter om R9 3950X ytelse gjør den til en veldig fristende kandidat. MD Ryzen 9 3950X 16 Core Crushes The Intel Core i9-10980XE 18 Core CPU in 3DMark Firestrike – Up To 24% Faster Than Intel’s Flagship HEDT https://wccftech.com/amd-ryzen-9-3950x-and-intel-core-i9-10980xe-cpu-3dmark-benchmark-leak/ EDIT: Har bestemt meg, det blir 3950X@X570 så fort det kommer i butikken. Skulle gjerne reservert så man slapp vente. Fars julegave i 2019 og 10 år siden sist. Bygget vil også ha 64GB minne til VM labbing. 2x32GB siden det er snakk om dual-channel minnekontroller.Da er det bare å begynne å sette opp bygglista Tenker da jeg går for disse minnebrikkene (om det har noen reell hensikt å velge b-die til 3950X) G.Skill Trident Z RGB DC DDR4 3200MHz 2x32GB (F4-3200C14D-64GTZDCB) veldig fristende å gå for disse til halve prisen: Corsair Vengeance Black RGB LED DDR4 2933MHz 2x32GB (CMK64GX4M8Z2933C16) Ser at 2933Mhz CL16 på eks. 3900X kan koste deg ca. 6 FPS i BF5. På en annen side kan jeg få 128GB til samme pris som Trident brikkene. Kjøre BF5 fra ramdrive? https://www.maketecheasier.com/setup-ram-disk-windows/ . Endret 21. oktober 2019 av Theo343 Lenke til kommentar
Nizzen Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 Theo343: Du ombestemmer deg når du oppdager det egentlige resultatet til 10980XE Det er ikkje 25k, men 40k ? Lenke til kommentar
Theo343 Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 Haha det kan fort skje ja Nizzen. Er bare 1 ting som er 100% sikkert nå og det er at en ny rigg står her i år. 1 Lenke til kommentar
Theo343 Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 Problemet er at nå vil jeg ha dette hovedkortet. 1 Lenke til kommentar
Malvado Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 Problemet er at nå vil jeg ha dette hovedkortet. https://www.youtube.com/watch?v=qszxxIumJOQ Har hørt bare godsnakk om det nå etter siste bios oppdatering. Sitter på et Elite selv og er godt fornøyd , men har trolig passet bedre med det du viser fram til en 3950x... Lenke til kommentar
Betroz Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 (endret) Har bestemt meg, det blir 3950X@X570 så fort det kommer i butikken. Kanskje bedre å vente til 3950X blir sammenliknet mot 10980X (og 9900KS) fra slike som GamersNexus og Guru3D...? Problemet er at nå vil jeg ha dette hovedkortet. Sjekk om det hovedkortet virker best med 4 eller 2 brikker før du handler. Som jeg har sagt før, 8GB brikker klokker bedre enn 16GB brikker. Endret 21. oktober 2019 av Betroz Lenke til kommentar
Theo343 Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 Kan nok hende jeg må vente til 19. november med å bestemme meg ja. Lenke til kommentar
Betroz Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 Kan nok hende jeg må vente til 19. november med å bestemme meg ja. Kan være lurt, iallefall når du først skal svi av en stor sum penger. Men går jo an å ordne med de andre delene til bygget, så de er klare da. F.eks hvilket kabinett skal du putte din 3950X / 10980XE / 9900KS inn i da? Lenke til kommentar
Theo343 Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 (endret) Det blir nok et Fractal Design Define R6 eller meshify. Har en formening om det meste da jeg laget en liten liste i våres. Endret 21. oktober 2019 av Theo343 Lenke til kommentar
Betroz Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 (endret) Det blir nok et Fractal Design Define R6 eller meshify. Meshify S2 vil gi litt bedre airflow over standard R6. Bytt ut viftene med noen bedre. Ha 3 stk i front, Silent Wings 3 140mm vifter f.eks og en bak. Endret 21. oktober 2019 av Betroz Lenke til kommentar
N o r e n g Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 EDIT: Har bestemt meg, det blir 3950X@X570 så fort det kommer i butikken. Skulle gjerne reservert så man slapp vente. Fars julegave i 2019 og 10 år siden sist. Bygget vil også ha 64GB minne til VM labbing. 2x32GB siden det er snakk om dual-channel minnekontroller. Da er det bare å begynne å sette opp bygglista Tenker da jeg går for disse minnebrikkene (om det har noen reell hensikt å velge b-die til 3950X) G.Skill Trident Z RGB DC DDR4 3200MHz 2x32GB (F4-3200C14D-64GTZDCB) veldig fristende å gå for disse til halve prisen: Corsair Vengeance Black RGB LED DDR4 2933MHz 2x32GB (CMK64GX4M8Z2933C16) Ser at 2933Mhz CL16 på eks. 3900X kan koste deg ca. 6 FPS i BF5. På en annen side kan jeg få 128GB til samme pris som Trident brikkene. Kjøre BF5 fra ramdrive? https://www.maketecheasier.com/setup-ram-disk-windows/ Du mister minst 5% spillytelse ved å gå ned fra 3733 MHz til 3200 MHz også, men det skjer ikke at du klarer å kjøre quad rank B-die på 3733 MHz. Tviler på at du klarer å kjøre stramme timings på såpass tettpakkede brikker, som strengt tatt er enda viktigere enn primære timings på Ryzen fordi AMDs AGESA ikke ser ut til å konfigurere spesielt gode timings automatisk. Lenke til kommentar
Theo343 Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 (endret) Meshify S2 vil gi litt bedre airflow over standard R6. Bytt ut viftene med noen bedre. Ha 3 stk i front, Silent Wings 3 140mm vifter f.eks og en bak. Vurderer også Phanteks Evolv X. Endret 21. oktober 2019 av Theo343 Lenke til kommentar
N o r e n g Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 Problemet er at nå vil jeg ha dette hovedkortet. Forresten, Buildzoid testet dette opp mot ASUS C8F i sommer, og oppdaget at det var praktisk talt ingen forskjell på de områdene Aorus Xtreme burde gjøre det bra. Lenke til kommentar
Theo343 Skrevet 21. oktober 2019 Rapporter Del Skrevet 21. oktober 2019 Du mister minst 5% spillytelse ved å gå ned fra 3733 MHz til 3200 MHz også, men det skjer ikke at du klarer å kjøre quad rank B-die på 3733 MHz. Tviler på at du klarer å kjøre stramme timings på såpass tettpakkede brikker, som strengt tatt er enda viktigere enn primære timings på Ryzen fordi AMDs AGESA ikke ser ut til å konfigurere spesielt gode timings automatisk. Tenker at jeg må bruke denne ja. https://www.techpowerup.com/download/ryzen-dram-calculator/ Lenke til kommentar
