Pct's Wotlk beta/info tråd
Vel, noen må jo ei formening om hvordan de foretrekker akkurat nå, selv om det endres etter hvert.
Tror nok jeg levler priesten først, da det er den karakteren jeg har likt best hit til i allefall.
Fra en blå post:
Shadowpriests in WotLK
We test single target DPS with blue, epic and green gear. In all trials the Shadow Priest was doing more than expected DPS, I believe it was around ~2500 in epics. This was solo in a 5-minute trial (without raid buffs). In a raid setting, your DPS would probably be significantly higher. In a nutshell, we feel we've made a lot of progress in our goal of bumping the Shadow Priest DPS numbers/scaling to where we want it to be. Unfortunately players won't really be able to see these numbers on their characters because you are using low tier PvP gear. (Referring to the pre-mades we have on Murmur)
Shadow Priests raid buffs are Misery and Replenishment. We removed a lot of +% spell damage modifiers throughout all classes. Those that do exist are exclusive with similar debuffs. This is all part of our goal to simplify the requirements of a raid group building/composition. In return, we significantly scaled Shadow Priests damage up.
If you have a Moonkin or Shadow Priest present in your raid group regularly, your raid can nix 3% hit off their itemization budget. As for the talent not being always useful for the Priest (say, everyone is already hit capped) it now provides a selfish boost to the Priest (15% coefficient scaling on three spells).
Shadow Word: Death was initially created as a finisher spell. While the glyph may not be amazing in a raid setting, it's quite useful soloing to finish off mobs or in PvP where you want to finish off foes.There's something for everyone in the new glyphs, it's very difficult to please every flavor of Priest (PvE Holy, PvP Holy, PvE Shadow, etc.). The nice thing about glyphs is that we can add new ones whenever we want, so expect new ones throughout the patch cycles.
Without Dispersion, Shadow Priests would not be PvP viable. Our goals were to 1] Lower the Shadow Priests raid utility but increase their personal DPS, 2] Give the Shadow Priest more PvP mobility and survivability, and 3] Give them a new niche/gameplay (AOE damage with Mind Sear). I think we accomplished all of those goals. Its quite possible we may of not went far enough (or even too far), but we'll find that out soon enough and do changes where necessary.
While Dispersion might not drastically increase your raid damage, not all talents are designed as such. We experimented with giving it some added DPS to it, but we had to take it off because the Shadow Priest was exceeding our bench mark for DPS. It was also strange gameplay (what if you got hit while it was channeling? You'd feel really bad. Also its supposed to be your defense mechanism in PvP, but yet now you want to use it for DPS?)
Hva skal det bety? (Koraa som skrev det jeg siterte).
REDIGERT:
Shadow priests are probably doing the most damage at the moment. :)
With all the changes right now, class balance is something like an avalanche rolling down a mountain. It's hard to look out at another class or spec and figure out who is ahead of your or behind. Wait until things stabilize a little more, and everything should look a little flatter.
Fra Ghostcrawler.
Så hva mente du egentlig? At du vet bedre enn Blizzardfolka?
Endret av Matsemann
Det er da flott å komme med en påstand og så ikke gidde å backe den opp, annet enn én lenke til et annet forum. Kunne vel kommet med noe litt mer konkret?
Jeg siterte dessuten Ghostcrawler i min forrige post, og han sa også at spriest gjør mest skade for øyeblikket.
Endret av Matsemann
PvE er uansett ikke det viktigeste for meg. Mtp PvP har ikke shadow priests fått noe nytt som kommer til å utgjøre noen særlig forskjell (nei, dispersion er ikke så mye å klappe for).
Endret av ahpadt
Hvor er warrior? Griner hvis arms eller fury warrior er UNDER Holy Priest på DPS. :cry:
Fortsatt, det er 2 måneder til WotLK release, hvis holy priest er over fury/arms warrior på dps allerede nå, har blizzard gjort noe feil, imo.
Endret av GuQQa
Enhancement Shaman... HÆ?
Jada, de bruker spells. Men er fortsatt en melee-classe (/spec) vil jeg og sikkert veldig mange andre si.
Endret av GuQQa
Igjen, ingenting er ferdig....................................................................................
Ingenting er ferdig, men det virker ikke helt som Blizzard skjønner problemet med shadow priests, noe som gjør ting vanskligere for dem når det gjelder å fikse problemet.
Sist jeg sjekka var ikke warriors klassifisert som casters.
Paladin?
