WoW: BC - raidinstance cap på 25spillere
Molten Core. Blackwing Lair. The Temple of Ahn'Qiraj. Naxxramas Necropolis. And nothing else. Looking ahead to Blizzard's expansion for World of Warcraft, Burning Crusade, the aforementioned instanced raids will be the last of Blizzard's 40-man raid content. In Burning Crusade, end game raiding (which occupies WoW's max level players) will be done in groups of 25 or 10. Illidan's Black Temple, the most challenging raid instance that will appear in Burning Crusade (at release), has a 25-player limit.
Player versus Player combat will receive a major overhaul in Burning Crusade, one far greater than the upcoming cross-server battlegrounds system Blizzard recently detailed. Burning Crusade will introduce "Arena PvP." Lead designer Tom Chilton explains this new form of PvP: "It uses a team-based approach. So, much like forming a guild, you can form an arena team. You'll be able to go and get yourself an arena team charter; it can be for a 2-on-2 format, a 3-on-3 format or a 5-on-5 format." Chilton continues, "For example, for a 2-on-2 team you could have four people on the roster. For a 5-on-5 team you could have 10 people on a roster. You can have your substitutes, your benchwarmers, etc. And that should make it interesting, because we use a seasonal-based concept for the arenas. So you form your team, and your team may change in rating throughout the season. At the end of each week, based on your team's rating, you get a number of points that you can spend on the gear."
It's true, the plan is for five-player capped grouped dungeons. Ten-player capped raid dungeons. As well as Twenty-five-player capped epic raid dungeons. We wanted to focus on smaller raid environments, primarily to allow for greater individual player contribution. Also, in these smaller environments, hybrid classes have more opportunity to shine.
Tja.. Vet ikke helt hva jeg skal tro
source
EDIT: bleh, for treig
Endret av nazrm
eneste jeg syns var digg var illidans black temple.
6659809[/snapback]
*sikle*
Gleder meg.
Kanskje de klarer å gi warlocks flere oppgaver enn "keep this mob banished" og..
Bra måte å ødelegge guilds på. Top notch, right on, high five, cheers.
6660062[/snapback]
Hvis dere har under 50 signs for et 40-manns raid er vel guilden på god vei allerede..
Gjest
