AMD Zen 6 10000 serie
Skulle akkurat til å si, nå er du tidlig ute, men ser du er klar over det selv også da 😅
Fikk AI til å summere opp ryktene basert på alle lenkene jeg hadde samlet så langt:
AMD Zen 6 Rumors Summary Report (as of February 2026)
This report consolidates all currently circulating rumors about AMD’s Zen 6 microarchitecture from credible hardware sites and leaks.
1. Core Architecture & CCD Design
  • Zen 6 mainstream CCD will feature 12 cores (up from 8) in a single CCX with 48 MB L3 cache (up from 32 MB), a 50% increase in both cores and cache per chiplet.
    • Sources:
      • https://www.guru3d.com/story/zen-6-rumor-amd-shifts-to-12core-ccd-with-bigger-l3/
      • https://wccftech.com/amd-zen-6-ccd-slightly-bigger-than-zen-5-50-percent-more-cores-cache-tsmc-n2/
  • CCD die size is approximately 76 mm² (vs ~71 mm² for Zen 5, ~72 mm² for Zen 4), only a modest 5–7% increase despite the 50% higher core/cache count.
    • Source: https://wccftech.com/amd-zen-6-ccd-slightly-bigger-than-zen-5-50-percent-more-cores-cache-tsmc-n2/
  • Zen 6 CCDs retain full 3D V-Cache compatibility. Future X3D variants could reach 144 MB L3 per CCD, enabling up to 288 MB total on dual-CCD desktop parts.
    • Source: https://www.guru3d.com/story/zen-6-rumor-amd-shifts-to-12core-ccd-with-bigger-l3/
2. Process Node
  • Zen 6 CCDs will be manufactured on TSMC N2 (2 nm-class nanosheet/GAA). EPYC Venice confirmed as the first product on N2.
    • Sources:
      • https://wccftech.com/amd-shows-off-worlds-first-2nm-venice-zen-6-cpu-instinct-mi455x-gpu-helios-ai-rack/
  • Some reports mention possible use of N2P or fallback to N3P for certain SKUs, but N2 remains the primary node.
3. Desktop CPUs
  • Expected up to 24 cores / 48 threads on high-end parts (2 × 12-core CCDs).
    • Source: https://wccftech.com/amd-next-gen-zen-6-cpus-over-70-percent-performance-efficiency-improvement/
  • Potential for significantly higher X3D cache (up to 288 MB total on dual-CCD).
  • HWMonitor has added support for Ryzen 9850X3D (Zen 5 X3D with higher clocks) but also preliminary support for Zen 6 Medusa Point mobile, indicating broader Zen 6 tooling is in progress.
    • Source: https://wccftech.com/hwmonitor-receives-latest-update-offering-support-to-zen-6-medusa-point-ryzen-9850x3d-and-arrow-lake-refresh/
4. Mobile CPUs (Medusa Point)
  • Monolithic design using Zen 6 cores, RDNA 3.5 iGPU (8 CUs), FP10 socket.
    • Sources:
      • https://wccftech.com/amd-zen-6-medusa-1-a0-silicon-stepping-spotted-in-nbd-shipping-manifest-with-28w-tdp/
      • https://wccftech.com/amd-zen-6-medusa-point-high-tdp-and-low-tdp/
      • https://wccftech.com/amd-confirms-zen-6-medusa-cpus-2027-next-gen-gaming-gpu-improved-ai-raytracing/
  • TDP variants: 28 W (Low-TDP) and 45 W (High-TDP).
    • Sources:
  • Core counts: 10–22 cores total.
    • High-TDP (Ryzen 9): up to 22 cores (12-core CCD + 4 classic + 4 dense + 2 low-power).
    • Mid-range (Ryzen 7/5): 4 classic + 4 dense + 2 low-power.
    • Sources:
  • Early A0 stepping silicon (Medusa 1) already shipping for validation.
    • Source: https://wccftech.com/amd-zen-6-medusa-1-a0-silicon-stepping-spotted-in-nbd-shipping-manifest-with-28w-tdp/
  • Launch expected in 2027.
    • Source: https://wccftech.com/amd-confirms-zen-6-medusa-cpus-2027-next-gen-gaming-gpu-improved-ai-raytracing/
5. Server / Data-Center CPUs (EPYC Venice)
  • Up to 256 cores (Zen 6C dense variant) or 192 cores (standard Zen 6).
    • Sources:
      • https://wccftech.com/amd-next-gen-zen-6-cpus-over-70-percent-performance-efficiency-improvement/
  • Embedded variant (EPYC 9006) offers up to 96 Zen 6 cores with PCIe Gen6.
    • Source: https://wccftech.com/amd-epyc-9006-embedded-venice-cpus-96-zen-6-cores-embedded-2005-fire-range-annapurna/
  • >70% performance & efficiency improvement and >30% thread density vs EPYC Turin (Zen 5), measured in SPECrate 2017 INT (2P platform).
  • Physical chips shown publicly by Lisa Su at events (world’s first 2 nm chips).
    • Source: https://wccftech.com/amd-shows-off-worlds-first-2nm-venice-zen-6-cpu-instinct-mi455x-gpu-helios-ai-rack/
  • Launch expected in second half of 2026.
    • Sources:
      • https://wccftech.com/amd-confirms-zen-6-zen-7-cpu-core-architectures-more-performance-efficiency-ai/
6. Software & Tooling
  • GCC 16 has merged Znver6 target for Zen 6 optimization.
    • Source: https://wccftech.com/amd-zen-6-support-added-to-gcc-16-ahead-of-launch/
  • HWMonitor added preliminary Medusa Point support.
En vegg av tekst fra AI - som egentlig ikke tilføyer noe nytt. Mange av linkene bruker HXL og hverandre som kilde og skriver om kapp for å melde om det samme.
Jeg er mest spent på
- om 10000-serien vil kreve nye brikkesett eller kan brukes på eksisterende AM5 hovedkort
- klokkehastigheter vs 9000-serien
- X3D-modeller
- priser
- Prosessnode (N2 eller om de går for en av backup-planene)
- G-modeller med mer enn 8 CU
Endret av Simen1
  • Innsiktsfullt 2
Simen1 skrev (29 minutter siden):
Det er vel bekreftet av AMD men limer inn et AI svar. Ryktes også Zen7 på AM5
Support for AM5: Major manufacturers like Asus, ASRock, and MSI have confirmed that Zen 6 CPUs will work on existing AM5 motherboards, requiring only a BIOS update.
Simen1 skrev (32 minutter siden):
Har ikke lest at det er bekreftet  men det tyktes at Zen 6 spres utover flere 2nm (N2,N2P og N2X) og muligens 3nm på svakeste modeller. Vil tro det fort kan endre seg i dagens verden med AI boble.
Simen1 skrev (37 minutter siden):
Har ventet på en skikkelig APU i 8 år. men gi meg en 8 kjerne med 30-40CU og drøyt med cash for å kopensere for minnet :)
leifeinar skrev (1 time siden):
AMD Ryzen Al Max+ 388 har alt du ber om, men jeg er usikker på hvor tilgjengelig den blir. Jeg liker wikipediasiden, for det er så lett å sammenligne.
Edit: Den selges visst her.
Steam Machine er en litt billigere variant.
Endret av Simen1
Bedre tidelig ute enn Zen....
Blir spennende å se hva telsen blir. Jeg håper på 30%+ gaming ytelse i Battlefield 6. Enda bedre imc slik som Apuene har. Slik at 10 000 ddr5 blir lett å kjøre 😎🤟
Endret av Nizzen
  • Innsiktsfullt 1
  • 3 uker senere...
  • 3 uker senere...
Simen1 skrev (På 20.2.2026 den 22.17):
Det ryktes at Ryzen 10000-serien (Zen6) utsettes til over nyttår (2027).
Tror det kan avhenge av priser på ram/GPU på aktuelt tidspunkt, samt lansering av Nova Lake. Hvis Nova Lake lanseres høsten 2026 og er konkurransedyktig med Zen 5, kan nok AMD se gevinsten av å ikke vente.
Er ikke sikkert priser på ram er så avskrekkende. DDR5 har vært tilgjengelig lenge nå, og det er nok mange som allerede har ram, men samtidig har en eldre AM5-CPU som de kunne tenkt seg å oppgradere. Jeg er fristet til å oppgradere fra 7700 og spesielt en "rimelig" 12-core.
Endret av Donkey Kong
  • Innsiktsfullt 1
Sitat
Phison has issued another warning sign for the storage industry, and this time the message is hard to ignore. CEO Khein-seng Pua says some NAND flash suppliers pushed through price increases of around 50% almost overnight, reflecting a market under heavy strain.
https://www.guru3d.com/story/phison-warns-nand-prices-surged-as-ai-demand-tightens-supply/
NAND og Ram lages visst fra samme type wafer så det tyder på at også ram-prisene er sterkt presset. Jeg tror ikke dette går over med det første.
En annen ting er at stengningen av Hormuz-stredet kan skape ringvirkninger i Taiwan, nærmere bestemt et kraftig prishopp på både gasskraft-strøm til TSMC (som bruker nesten 10% av Taiwans elkraft), og prishopp på kobber, wafere og kjemikalier som brukes i produksjonen.
  • Innsiktsfullt 1
