Problem med AoE2
Hei.. jeg sitter på et lan akkurat nå. 4stk har XP, og 1 har Vista.
Problemet vårt er at alle de med XP finner hverandre i multiplayer, men vista maskinen klarer ikke å koble seg opp sammen med de andre.
Noen som vet en løsning på dette?
Takk på forhånd for raske og gode svar :D
ja :( har prøvd begge deler, og ingenting fungerer.
Jeg har også deaktivert brannmuren.
Alle finner banene, men bare de med XP kommer innpå den.
The Vista to XP Lan Games connection problems Solution!!
After trying to play several different lan games with my Vista equipped machine and not being able to join I finally found the way to make it work!! OH JOY! SO many forums browsed in vain. Finally I found it. For all of you, the problem was ipV6.
To fix that problem you need to disable ipv6:
1- Open the Network and Sharing Center in the Control Panel on the Vista equipped machine
2- Click on the little blue letters "View Status" next to your LAN connection (my wireless connection for me)
3- Then click on the Properties button (not wireless properties or anything else, just properties)
4- Click continue on the little annoying pop-up vista window if any
5- Now look for the field under "this connection uses the following items" there with Client for Microsoft Networks/QoS Packet Scheduler etc. You should find many of those with little checkboxes next to them.
6- Now i'm not very sure if it's only ipV6 that you need to disable, so to make sure, do steps 1-5 with you XP equipped machine to check what they have in that field, and keep the checkboxes checked for only those items. Uncheck everything else. I uncheked Internet Protocol Version 6 (TCP/IPv6) , and the two Link-Layer ones.
7- Try again to join your lan game it should work fine ( it did for me and our Dungeon Siege 2 Lan Party!)
Dere kan jo prøve dette... Kopiert fra: http://forums.techarena.in/windows-vista-games/591735.htm
Det er "Internet protocol version 6 (TCP/IPv6)" Jeg skal skru av?
Jeg har forsåvidt gjort dette, og jeg finner fremdeles ikke de andre i multiplayer. Har også åpnet for AoE i brannmuren :)
Jeg fikk det ikke til, men nå gjør det ingenting :p Er hjemme fra LANet igjend.. Men takk for alle de gode tipsene Strepto :D
