Patch Problemer WoW..!
Av en eller annen grunn vil ikke patchen som står skrevet under feste seg til spillet mitt. Kan noen linke meg den eller hjelpe meg?? plz :(
Dette står når den er ferdig å patche:
"The update could not be applied
The file "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\World of Warcraft\World of Warcraft.lnk.Temporary" could not be created. If this problem persists, you may be able to solve it by uninstalling and then reinstalling the game. If you are unable to correct this problem, please contact Blizzard Technical Support. (InstallerFile::Create)"
Patchen:
WoW-1.12.x-to-2.0.1-enGB-patch
  • 2 uker senere...
