Historier bak Classes!
Tror da ikke det finnes tempelriddere eller så det kan være det samme....  paladins er dps fanbois.. end of story
7427876[/snapback]
Nå tror jeg du er litt ute på viddene her+ - hva mener du med dette? - Paladins er da ikke en DPS klasse? - Vi er den beste support-klassen i spillet?
Endret av kjetilkl
Paladin = BEST DPS CLASS I HELE SPILLET!!1111
7428409[/snapback]
hva er forresten en DPS klasse?
7429565[/snapback]
Særiøst svart.
Dps
-Mage
-Hunter
-Rogue
-Warlock
-Fury eller Arms warrior
Andre klasser er enten healer eller hybrid klasser.
Funker til begge deler, men har ikke samme mulighet for skade som klassene over. :)
Håper det var til hjelp.
7428409[/snapback]
7429565[/snapback]
Særiøst svart.
Dps
-Mage
-Hunter
-Rogue
-Warlock
7429628[/snapback]
men palladins kan jo både heale og resse...så de er da IKKE DPS klasse da.
7428409[/snapback]
7429565[/snapback]
En klasse som gjør skade.
Akkurat som listet over her et sted...
DPS=Damage Per Second.. ?
Edit:
Vil si Paladins er en supportklasse ja. Buffs og healing er noe de kan. Og de tåler å bli slått på.
Endret av Caddy
Hunter
Rangers are skilled stalkers and hunters who make their home in the woods. Their martial skill is nearly the equal of the fighter, but they lack the latter's dedication to the craft of fighting. Instead, the ranger focuses his skills and training on a specific enemy—a type of creature he bears a vengeful grudge against and hunts above all others. Rangers often accept the role of protector, aiding those who live in or travel through the woods. His skills allow him to move quietly and stick to the shadows, especially in natural settings, and he also has special knowledge of certain types of creatures. Finally, an experienced ranger has such a tie to nature that he can actually draw on natural power to cast divine spells, much as a druid does, and like a druid he is often accompanied by animal companions. A ranger's Wisdom score should be high, as this determines the maximum spell level that he can cast.
Forklaringen er fra verdens beste pc rollespill basert på verdens beste rl
rollespill. Neverwinter nights classses
Rollespill fanatiker - Tormod
Hunter
7429798[/snapback]
Tusen takk for at det finnes noen som virkelig vet hva rollespill er og ikke bare sammenligner hunter med legolas.
Shaman=Jesus
De kan stå opp fra de døde
De kan gå på vannet
De kan gjenopplive de døde
De kan heale de skadde
7430427[/snapback]
hva, kan shamaner stå opp fra de døde?
7433642[/snapback]
Ankh. Nesten samme som Soulstone.
Shaman=Jesus
De kan gå på vannet
Ikke glem frostshock!
Frostshock > +10 all stats / blessing of protection / blessing of wisdom :)
Endret av stigos3000
