Thunderbird - "Innkommende og Utgående tjenere"
2bb1
Hei :)
Har nå installert Mozilla Thunderbird som jeg har tenkt å bruke til min hotmail konto. Når jeg skal lage en profil, må jeg skrive inn "Inkommende tjener" (Skriv inn navnet på tjeneren du henter e-posten fra). og "Utgående tjener" (Skriv inn navnet på tjeneren du bruker for å sende e-post).
Noen andre som bruker Thunderbird som kan hjelpe meg? :)
Mvh Torbjørn.
Endret av 260202
Can I access my Netscape WebMail or Hotmail accounts through Thunderbird?
No. Netscape WebMail and Hotmail use proprietary protocols. To access WebMail directly through an e-mail client requires you to use Netscape 6+ with AIM; to do so with Hotmail requires either Microsoft Outlook or Outlook Express. Of course, you can access your WebMail account on the Web at http://webmail.netscape.com/, or Hotmail at http://www.hotmail.com/.
Bruk Outlook :(
Access your MSN Hotmail account from Microsoft Outlook
To protect our users from the increasing amount of unsolicited junk e-mail or spam sent from MSN Hotmail accounts through Microsoft Outlook and Microsoft Outlook Express, we have reluctantly had to restrict the new use of Microsoft Outlook and Microsoft Outlook Express to subscribers.
If you use Microsoft Outlook 2002 or 2003, you can set up a separate Inbox for your Hotmail account within Outlook. This option is currently available for Microsoft Windows operating systems only.
In Outlook, click the Tools menu, and then click E-mail Accounts.
Click Add a new e-mail account, and then click Next.
Click HTTP, and then click Next.
Type your user and sign-in information, and then make sure Hotmail is selected as the HTTP Mail Service Provider.
To help protect your privacy, do not select the Remember password check box unless you are the sole person with access to the program. If you do not select the Remember password check box, you will be asked to enter your password in step 5.
Do not select the Log on using Secure Password Authentication (SPA) check box.
Click Next, and then click Finish.
Note
After you set up your Hotmail account in Outlook, your Hotmail folders appear in the Outlook folder list.
Edit: erstatta link med forklaring, siden linken ikke fungerte.
Endret av Luzifer
Du er nødt til å bruke en extension kalt WebMail og den tilhørende Hotmail-delen.
Jeg driver selv og prøver ut/sliter med dette, men jeg tror det er TB 1.0.7 som er problemet, og at jeg må bruke enten 1.0.6 eller 1.5 RC1 for å få det til å fungere. Det var ihvertfall det jeg fikk til svar her.
Okai... Ser ut som der er en del som må leses gjennom ja. Får ta det i morgen, for nå er det senga next. :)
EDIT: Luzifer, så ikke at du hadde "Editet" teksten din, så fikk ikke med meg at du hadde skrevet noe om det. Men takk uansett :p
Endret av 260202
For å bruke Hotmail med Mozilla Thunderbird må du:
1. Laste ned HotmailPopper.
2. Installere programmet.
3. Evt åpne programmet, hvis ikke dette er blitt gjort automatisk etter installasjonen.
4. På oppgavelinjen ser du et nytt ikon, høyreklikk på den og velg "Options".
5. Instillingene skal være som følger (klikk link)
6. I "Password" feltet, skal du selvfølgelig skrive inn hotmail-passordet ditt.
7. Så må du inn i Thunderbird og endre "Innkommende og Utgående tjenere" til 127.0.0.1.
8. Restart Thunderbird, og la Hotmail Popper kjøre i bakgrunnen hver gang du vil bruke Hotmail med Thunderbird.
Bruker selv denne metoden og det funker perfekt. ;)
Lykke til. :)
Endret av Espen54
Lykke til. :)
5126684[/snapback]
Takk, endelig en greie som fungerer (har prøvd Mr.Postman tidligere uten hell). :)
Men jeg venter fremdeles på at TB 1.5 final og en oppdatert versjon av WebMail kommer ut, slik at jeg kan bruke Hotmail uten å ha andre programmer liggende å kjøre i bakgrunnen.
Ja, kommer nok til å bytte når det kommer ut jeg også, så jeg slipper andre programmer som kjører i bakgrunnen. Men får bruke HotmailPopper så lenge. :)
Endret av Espen54
Update:
Jeg fikk nå noen linker til oppdaterte versjoner av WebMail og Hotmail-delen som fungerer med Thunderbird 1.5 RC1 (fra TB 1.4 til 1.6).
http://download.mozdev.org/webmail/web-mail-0-8-0.xpi
http://download.mozdev.org/webmail/hotmail-0-9-0.xpi
Disse fungerer veldig bra etter alt jeg kan se, men jeg må også legge til at alle de leste mailene mine ble slettet første gang den logget seg inn på kontoen min. Så hvis du forstatt vi ha alle mailene dine tror jeg du må markere hele bunten som ulest.
Jeg er overhodet ikke sikker på om de blir slettet da heller, så dette gjøres på eget ansvar.
Edit: Man må hake av på 'La meldinger ligge på tjener' under 'Kontoinstillinger' -> 'Tjenerinstillinger' for at meldingene ikke skal bli slettet.
Endret av endrebjorsvik89
