Innos Skrevet 1. august 2005 Skrevet 1. august 2005 (endret) Laster ned den nye patchen nå, blir spennende å se. -------------------------------------------------------------------------- Diablo II Version History -------------------------------------------------------------------------- - Patch 1.11 -------------------------------------------------------------------------- A new Mystery has been revealed! - Players of Hell Difficulty Realm games are hereby warned once again, that a series of new and challenging tests await you! The answer lies within Diablo's Bosses, which span across the world from the Den of Evil to the Throne of Destruction... New Items - Added 10 New Runewords. - Added new Unique Items that will drop from Special Bosses. Hireling Enhancements - Players can purchase hirelings that are within 1-5 levels below their own level. - The rate at which hirelings gain experience has been increased. They should now stay closer to the player's level. Major Bugs - Creating a town portal when corpses or other objects entirely fill the area where the portal will appear in town will no longer crash the game. - Skills obtained from runewords created while the item is equipped will no longer disconnect you from Battle.net when chosen. - Barbarians will no longer become stuck when using Whirlwind right after Inferno from the unique item Balrog Blade Flamebellow. - German, Spanish, and Polish users will no longer crash when the mouse cursor moves over an item that grants an Aura while equipped. - The game will no longer crash when selecting a skill granted by a weapon at the same time as switching weapons with the W key. - Dying or being requested to trade while changing the key configuration will no longer cause you to get stuck. - The "Missile Firing too far" assertion error has been corrected. - Attempting to sell a Horadric Cube or a quest item to an NPC by holding Control while clicking will no longer disconnect you from Battle.net. Minor Bugs - Running the game with -install no longer causes the game to be installed as a Windows Service. -install is now ignored. - Sometimes the seals in Diablo's lair would not activate. This has been corrected. - Character expiration messages have been updated to reflect the expiration policy implemented in patch 1.10. - Unidentified items sometimes caused other set items to display green for items the player does not have. This has been corrected. - The German mouseover text for the Ist rune has been corrected. - Account recovery is now allowed for existing accounts whose name is only one or two characters. - When leaving a game on Battle.net, you will now be brought back to the channel in which you were previously. - Transmuting an ethereal item now retains the ethereal stats bonuses. - In Japanese Lord of Destruction, items that add to all Assassin skills incorrectly stated in their mouseover text that they added to all Druid skills. This has been corrected. - Battle.net messages for non-English versions have been corrected. Fixed Game Exploits - It is no longer possible to bypass the 10-second hostility timer by activating a waypoint at the same time as declaring hostility. - Uber Diablo is no longer killed when Shenk the Overseer or Blood Raven die nearby. - Necromancers with Trang-Oul's Set equipped could sometimes become invincible to attack. This has been corrected. - Blessed Hammer no longer remains active while in town, preventing players from subsequently declaring hostility and having the hammers hit other players for damage. - Set items retained their multi-piece bonuses after the player died, even though they were removed. This has been corrected. - Items with skill-charging effects will no longer give synergy bonuses to skills when equipped on a character without those skills. - Pasting from the Clipboard no longer allows the creation of characters with more than one dash or underscore in their name. Endret 1. august 2005 av Innos
bjs Skrevet 1. august 2005 Forfatter Skrevet 1. august 2005 alle realms er nede til kl 23.00 i natt tror eg
Amon Amarth Skrevet 1. august 2005 Skrevet 1. august 2005 finner ikke cd'ne jeg... får trøste meg med wow.
Smeltelim Skrevet 1. august 2005 Skrevet 1. august 2005 Den lastes og installeres automatisk når du connecter til battle.net med diablo2
bozoc Skrevet 1. august 2005 Skrevet 1. august 2005 men jeg kommer ikke inn på battlenet. kan jeg ikke ta patchen ned på nettet en plass og innstalere den utn nett???
efikkan Skrevet 1. august 2005 Skrevet 1. august 2005 Den lastes og installeres automatisk når du connecter til battle.net med diablo2 Etter du har koblet til Battle.Net så blir den lastet ned i D2-mappa. Du kan kopiére den derifra om det er ønskelig. Så muligens dele den med andre som ikke kan koble opp. Dessuten kan det være praktisk å ha den liggende.
bozoc Skrevet 1. august 2005 Skrevet 1. august 2005 oki. men vænn av mæ har brent versjon kan han koble seg til battlenet.com da???
efikkan Skrevet 1. august 2005 Skrevet 1. august 2005 oki.men vænn av mæ har brent versjon kan han koble seg til battlenet.com da??? Jeg tror at alle kan koble seg til Battle.Net for å laste ned patcher, men de som ikke har gyldig serial ikke vil få logget seg inn. Det er mulig at jeg tar feil, men jeg mener at en jeg kjenner gjorde det med 1.10 uten problemer.
bozoc Skrevet 1. august 2005 Skrevet 1. august 2005 kommer det noen gang ut på nett så mann kan ta den ned sånn som de andre patchan?
efikkan Skrevet 2. august 2005 Skrevet 2. august 2005 kommer det noen gang ut på nett så mann kan ta den ned sånn som de andre patchan? Se her: http://www.blizzard.com/support/?id=msc0387p
Civilix Skrevet 2. august 2005 Skrevet 2. august 2005 Noen her som har prøvd de nye områdene? Når jeg loget inn igår hadde jeg 7x char expired, så da gadd jeg ikke å sette igang med å spille opp en ny char så sent...
DjSlayer Skrevet 2. august 2005 Skrevet 2. august 2005 Noen her som har prøvd de nye områdene? Når jeg loget inn igår hadde jeg 7x char expired, så da gadd jeg ikke å sette igang med å spille opp en ny char så sent... Det er 4 nye områder, disse åpner du med 3 forskjellige nøkler (key of terror, key of hate og key of destruction): ett sted hvor du finner Izual clone Ett sted hvor du finner Lilith Ett sted hvor du finner Duriel clone Disse "dropper" en artifakt (Diablos horn, Mephistos brain, Baals eye) som åpner uber Tristram, et sted hvor man ikke kan komme uforberet. Der møter man de tre brødrene Diablo, Mephisto og Baal. Vet ikke om det er noen i Europe som har fått tak i "hellfire torch" Large charm: +3 to class skills (assasin, druid, necromancer, barbarian, amazon, sorceress eller paladin) +10-20 res all +10-20 statpoints +8 to light radius 25% chance to cast lvl 10 firestorm on striking lvl 30 hydra (10 charges) - D.J.
Civilix Skrevet 2. august 2005 Skrevet 2. august 2005 Det er 4 nye områder, disse åpner du med 3 forskjellige nøkler (key of terror, key of hate og key of destruction):ett sted hvor du finner Izual clone Ett sted hvor du finner Lilith Ett sted hvor du finner Duriel clone Disse "dropper" en artifakt (Diablos horn, Mephistos brain, Baals eye) som åpner uber Tristram, et sted hvor man ikke kan komme uforberet. Der møter man de tre brødrene Diablo, Mephisto og Baal. Vet ikke om det er noen i Europe som har fått tak i "hellfire torch" Large charm: +3 to class skills (assasin, druid, necromancer, barbarian, amazon, sorceress eller paladin) +10-20 res all +10-20 statpoints +8 to light radius 25% chance to cast lvl 10 firestorm on striking lvl 30 hydra (10 charges) - D.J. hellfire torch har +1-6 to class skills Og det ryktes også om at den firestormen som er på den egentlig er "fire-nova". Har sett noe tall på at de nye områdene er drop lvl130+, noe som sansyndligvis vil si at de er veldig harde også, derfor hadde det vært intressangt og høre med noen som har vært i de nye områdene.
efikkan Skrevet 2. august 2005 Skrevet 2. august 2005 Noen her som har prøvd de nye områdene? Når jeg loget inn igår hadde jeg 7x char expired, så da gadd jeg ikke å sette igang med å spille opp en ny char så sent... Det er 4 nye områder, disse åpner du med 3 forskjellige nøkler (key of terror, key of hate og key of destruction): ett sted hvor du finner Izual clone Ett sted hvor du finner Lilith Ett sted hvor du finner Duriel clone Disse "dropper" en artifakt (Diablos horn, Mephistos brain, Baals eye) som åpner uber Tristram, et sted hvor man ikke kan komme uforberet. Der møter man de tre brødrene Diablo, Mephisto og Baal. Vet ikke om det er noen i Europe som har fått tak i "hellfire torch" Large charm: +3 to class skills (assasin, druid, necromancer, barbarian, amazon, sorceress eller paladin) +10-20 res all +10-20 statpoints +8 to light radius 25% chance to cast lvl 10 firestorm on striking lvl 30 hydra (10 charges) - D.J. Er det der sånn "ladder only"?
DjSlayer Skrevet 2. august 2005 Skrevet 2. august 2005 hellfire torch har +1-6 to class skills Og det ryktes også om at den firestormen som er på den egentlig er "fire-nova". Nei, de fleste som har droppet har +3, og jeg har sett ett skjermbilde av firestorm, det er ikke nova. charmen har ilvl 110 Den dropper på non ladder og ladder. her er en screenie av hellfire torch - D.J.
Xanitra Skrevet 2. august 2005 Skrevet 2. august 2005 så hvordan skaffer jeg meg en slik en da? Dukker disse monstrene opp random som Diablo clone`? eller kan du faktisk finne de. PS: Diablo 2 er tilbake, sletta WoW kontoen min nå ja.
DjSlayer Skrevet 2. august 2005 Skrevet 2. august 2005 så hvordan skaffer jeg meg en slik en da? Dukker disse monstrene opp random som Diablo clone`? eller kan du faktisk finne de. PS: Diablo 2 er tilbake, sletta WoW kontoen min nå ja. Nei, du må nok sette det igang selv. Du må ha totalt 9 nøkler (minimalt) de nøklene som er nevnt over. De dropper fra Nihlathak Countess, og Summoner. I akt 5 tar du en av hver nøkkel i cuben og trykker transmute, det vil da åpne en portal til enten duriel, lilith eller Izuael, noe som er helt tilfeldig. Du kan ende opp med å drepe Izuael flere ganger før du får resten av artifaktene, derfor så lønner det seg å ha flere sett med nøkler. Izuael, Duriel og Lilith vil droppe en artifakt hver (Mephistos brain, Baals eye og Diablos horn) de plasserer du i cuben og åpner über Tristram. Der finner du de tre brødrene Baal, Diablo, og Mephisto, den siste har fått en del forbedringer fra den Mephisto du dreper flere ganger daglig for itamz. Han er LE og har conviction aura. har hørt att ikke engang de beste hammerdins har så mye de skulle ha sakt der. - D.J.
