vALVE's aprilspøk, litt åpenbar?
Andre som har fått med seg den sjuke aprilspøken til valve?
Hehe..
Friday, April 1 2005
An update is available for Counter-Strike: Source. The update will be applied automatically when your Steam client is restarted. This update addresses requests for more realism in Counter-Strike: Source. The changes are as follows:
Features/Additions
Doubled player speed when jumping. The effect to cumulative, so the more you jump, the faster you go.
Cut price of AWP by 50%.
Added akimbo Riot Shield to buy menu.
Removed de_dust from mapcycle.
Enda mer er det. Dette var bare starten av updaten.. :!:
Endret av Gullegutt
Håper ikke det var noen som trodde på den? :no:
Edit: Resten:
Features/Additions
Realism Enhancements:
Knives:
Between rounds, it is suggested that you unsheath the weapon and repeatedly press the attack key to air it out as the leather now collects moisture and creates pits on the blade, making it less effective in the next round.
Shotguns:
1. Firing the shotgun without ammo loaded will now cause it to jam.
2. When the shotgun jams, press F2 to fill out form DA-1823-00/A12-H8.
3. You should then hear a scribbling sound. When it stops, press F3 to send the request to LIDM.
4. Failure to do paperwork before pressing F3 will result in the immediate return of the unrepaired shotgun.
5. The repairs can take 1-2 rounds for completion. During that time, you cannot purchase a replacement firearm and may only use your sidearm or knife.
Player Models:
Several models now feature eyewear. This is a completely cosmetic enhancement with the following exceptions:
Part EP-7829-292-2 must be purchased and worn correctly at all times in order to see during the round.
In between rounds, you may purchase and use part EC-2231-833-H34 to clean your EP-7829-292-2. Note: that this does not clean the eyewear itself!
To clean the eyewear, you need to purchase and use the designated cleaner, EC-2231-233-H34, EC-2231-523-H34, or EC-2231-239-H34a respectively depending on your model's eyewear. You can determine the part # of the correct cleaner by asking someone.
Machine and submachine guns:
At least once every five rounds, press F1 to inspect the weapon:
A musical cue indicates that the inspection has started. Now press F1 again repeatedly to clean and lubricate the weapon.
Your Preventative Maintenance Status (either "cleaning" or "lubricating") is determined by the speed with which you press the F1 key and will be displayed above your head.
To accurately simulate real life maintenance mistakes, pressing F1 too quickly will lubricate either the bolt face or the trunnion block. Pressing F1 too slowly sprays lubricant directly into the buffer tube. All mistakes render the gun inoperable, though this may not become immediately apparent.
Experiment with keypress timing to avoid (and discover!) other common maintenance errors.
In order to balance the improved stopping power of a well-maintained weapon, the reloading process has been made much less reliable.
When reloading, you should listen for two or three distinct clicks over a period of several seconds.
If you hear one click or no clicks or more than two clicks, you've bent the link ejector chute and the gun will most likely explode on the next attempt to fire it, though it may not.
© Valve Corporation. All rights reserved. Valve, Half-Life, and Counter-Strike are trademarks
and/or registered trademarks of Valve Corporation.
Endret av TheDarkListener
Pøh, det beste var "When the shotgun jams, press F2 to fill out form DA-1823-00/A12-H8." :!: :!:
Begynte å lure hva valve hold tpå med, men syntes det hadde vært digg jeg! Css har ikke cs feelingen uansett, hvor ikke bare gjøre det til et helt annet spill :D?
og det med å smøre automat-våpen... :wow:
HVIS det hadde vært ekte, da hadde CS:S mista MANGE spillere....
Nei det hadde fått flere spillere, spillet er alt for urealistisk idag!
Latterlig spøk :!: Og eg vil ikkje akkurat kalle det ein update heller meir ein what to do.
"At least once every five rounds, press F1 to inspect the weapon:
A musical cue indicates that the inspection has started. Now press F1 again repeatedly to clean and lubricate the weapon."(lol)
Endret av zefler
hvis spillet blir så innviklet som updaten sier, blir spiller altfor innviklet...hvis man skyter ei hagle uten ammo vil den låse seg, ga har du bare secondary i to runder? Realistisk - tja, men NO WAY! Nevn ET RPG-spill som er så realistisk....
Likte den med akimbo riot shields. For de som ikke vet, betyr akimbo å ha ett våpen i hver hånd. Altså ett riot shield i hver hånd. Kan vel bare dø bakfra da? :)
hadde vert artig vist valve gav ut denne patchen (og evt. fjerna den etter ein dag, men bare for å sjå korleis folk ville ha reagert).
Fra spøk til en litt mer seriøs bit: Jeg mener det faktisk ville vært bra hvis kniven ble sløvere hvis man skjerte i veggen og bakken.
Jeg fikk ikke meldingen før i dag tilig. Skjønte ikek en dritt ang. det med hagla, før jeg så datoen på updaten :p
