X800XT PE og minnehastigheter
Caliber
Tror ikke det er noen som vet det helt garantert, men mitt BBA kort har ihvertfall det.
Takk for svaret, selv om det ikke hjalp så mye. Lurer selvfølgelig på om mitt powercolor-kort har 1.6ns-minne. hvis noen kan svare på dette, vær så snill gjør det.
http://www.comseven.com/powercolor/X800XT_...num_edition.php
Edit:
Support Memory/memory bus width
- 256MB GDDR3 SDRAM
- 256 bit
Edit2:
Specifications
GPU RADEONTM X800 XT
Memory 256 MB 256-bit GDDR3 SDRAM
Core / Memory Speed 520/560 MHz
GigaFLOPS 200 billion floating point operations/sec
Transform Rate 780 million vertices/sec.
Memory Bandwidth 35.8 GB/sec.
Pixel Pipelines 16 extreme parallel pixel pipelines
Pixel Fill Rate 8.3 Gigapixels /sec.
DirectX Support 9.0
OpenGL Support 2.0
RAMDACs 400 MHz DACs
Output DVI-I / TV-Out / D-Sub/Video-In
Operating systems : Microsoft Windows XP, Microsoft? Windows 2000
Bus AGP 8X/4X
Endret av Ongabonga
Edit:
- 256MB GDDR3 SDRAM
- 256 bit
Edit2:
Specifications
DirectX Support 9.0
OpenGL Support 2.0
Bus AGP 8X/4X
Sier meg fortsatt ikke noe om hvor mange ns minnet er på... :D
http://forums.overclockersclub.com/?showto...20entry269424
Very nice review, but I would like to mention one thing about the conclusion.
You noted the card was almost $100 more than its bigger brother, the XT....which is true. You then talk about how you mod a Pro to an XT, which is a very misleading statement.
The X800Pro cannot be modded to a XT. ATi burns the pipelines on the regular Pro gpu before they leave the factory. A bridge connection will not fix these cards, and in the attempt will cause GPU failure.
The X800Pro VIVO can be modded to a X800XT-PE. ATi does not burn the pipelines on these cards, and they come with the XT's 1.6ns RAM. The X800Pro VIVO is nothing more than a rebadged X800XT-PE. Most even have X800XT-PE stickers on them. It is unclear as to how long ATi will continue to leave this doorway open, but it will be fixed some day.
I'm not trying to be a dick, so sorry if I come off that way. I just didn't want someone to try this mod on their X800Pro and have it die.
Der står det at XT bruker 1,6 ns RAM
Takk for hjelpen Ongabonga, det var akkurat det svaret jeg var ute etter!
De skal bruke 1,6 ns ja. Det vil likevel ikke si at du får 1,6 ns. :p Jeg hørte i allefall at det, pga av mangel på 1,6 ns minne, fantes 6800 Ultra kort (skal også ha 1,6ns) med 2 ns der ute.
Nettopp av slike grunner jeg undersøker dette på forhånd. Noen som kan henvise meg til en program hvor nettopp dette (hvor mange ns minnet har på et grafikkort) slik at jeg kan få sjekket dette på kortet når jeg mottar det?
Alle X800XT PE's har vel 1,6 ns minne?
Det er jo grunnen til at X800Pro VIVO-kortene kan gjøres om til X800XT PE fordi at de har 1,6 minne.
De vanlige X800 Pro har ikke 1,6 ns og kan derfor ikke gjøres om.
Bare å ta en titt på rambrikkene på kortet det ;)
Det sies så men det finnes Pro VIVO kort som har både 2ns og 1,6ns minne såvidt jeg forstår. Jeg ville absolutt ikke kjøpt Pro VIVO med troen på at man da er garantert XT PE. Det er mange som har fått problemer etter modding med ødelagte pipelines, vanskeligheter med å klokke til XT hastigheter osv.
