Acer Aspire 7720G eller HP Pavilion dv9687
patxi
Etter en stund har redusert valget på ny bærbar pc-en til disse to:
Acer Aspire 7720G Core 2 Duo T7500
(http://www.xd.no/aspx/produkt/prdinfovnet.aspx?plid=86445)
CPU: Intel Core 2 Duo T7500 (Santa Rosa)
Skjerm : 17" WUXGA+ high-brightness (200-nit) Acer CrystalBrite™ TFT LCD, 1920 x 1200 pixel resolution,
Minne : 2048 MB (2 x1024MB)
Harddisk : 250 + 250 GB Harddisk
Grafikk : Geforce 8600 GT up to 1280 MB of HyperMemory™ (512 MB of dedicated GDDR2 VRAM, up to 768 MB of shared system memory*), supporting Microsoft® DirectX® 10 and PCI Express®
Optisk enhet : HD - DVD Leser og DVD Brenner
Lydkort : Dolby®-certified surround sound system with two built-in Acer 3DSonic stereo speakers and one subwoofer supporting low-frequency effects, Intel® High-Definition audio support,S/PDIF (Sony/Philips Digital Interface) support for digital speakers
Batteri : 8 Celler
Eksterne porter : 4 x USB 2.0 ports,,1 x External display (VGA) port,1 x DVI, 1 x ExpressCard™/54 slot, 5-in-1 card reader (SD/MMC/MS/MS PRO/xD), 1 x S-video/TV-out (NTSC/PAL) port,1 x Consumer infrared (CIR) port , 1 x IEEE 1394 port ,1 x Modem (RJ-11) port , 1 x Ethernet (RJ-45) port ,1 x Headphone/speaker/line-out jack with S/PDIF support
Operativsystem :Windows Vista Ultimate Edition
Nettverkskort : 10/100 Mbit nettverkskort,Trådløst 802.11g/n WLAN
HP Pavilion dv9687 Intel Core 2 Duo T7500 (http://www.xd.no/aspx/produkt/prdinfovnet.aspx?plid=93493)
CPU : Intel® Core™ 2 Duo processor T7500 2,2 GHz. Nivå 2-cache: 4MB
Skjerm : 17" WXGA High Definition Brightview Widescreen 1440x900
Minne : 4048 MB (2 x 2048 MB) (Maks 4 GB DDR2 minne) NB: Kun ca. 3070MB RAM vil være synlig i Windows Vista 32-bit
Harddisk : 320 GB (2 x 160GB) SATA-harddisk, 5400 rpm
Grafikk : NVIDIA® GeForce™ 8600M GS
Optisk enhet : HD-DVD ROM med Super Multi DVD±R/RW Double Layer
Lydkort :3D Sound Blaster Pro-kompatibel lyd, 16 bits integrert Altec Lansing høytalere
Batteri : 8 cellers litiumionbatteri (li-lon) (90 W vekselstrømsadapter)
Eksterne porter : 3 USB 2.0, 1 HDMI, 1 VGA-port, 1 RJ11 modemkontakt, 1 RJ45 ethernet-kontakt, S-video TV-utgang, 2 hodetelefonutganger, 1 mikrofoninngang, 1 IEEE 1394, fjernkontroll-infrarødport (fjernkontroll tillegg), kabelforankringskontakt
Operativsystem: Windows Vista Home Premium Edition 32-bit
Nettverkskort : 10/100 LAN integrert, 802.11 a/b/g WLAN
Bluetooth: Ja, integrert
Noen som kan hjelpe meg å velge mellom?
Batteri : 8 Celler
Ville ha tatt Hp pc-en forde det er det pc merket jeg har har mest eraring med. Hp er veldig solide pc-er og god kvalitet.
På hp pc-en så er det mer ram selv om du bare får brukt 3,1 gb så er det likevel mer enn 2. Hp pc-en har også bluetoth som er innebygd.
Utseende messing synes jeg ikke acer pc-en er så veldig fin når du tar opp skjermen. Ser den mest ut som et leketøy der og da.
Det er hd-dvd avspiller på acern noe som ikke er vits å ha siden hd-dvd tapte kampen mot Blu-ray.
Om jeg hadde vært deg hadde jeg helt klart gått for hp pc-en.
Endret av Gryterett
Enig med deg.
HPren har også hd-dvd.
Det positive som jeg ser i Acern er: WUXGA skjerm, Grafikk og Vista Ultimate.
Det positive som jer ser i Hpen er: Minne, HDMI og bluetoth.
