reyerd Skrevet 30. mai 2007 Skrevet 30. mai 2007 Har en bærbar med en TSSTcorp TS-L532A cd/dvd brenner. Problemet er bare at den brenner ikke cd, har ikke testet dvd på lenge men sist jeg forsøkte funket det. Den brenner med det innebygde brenneprogrammet i xp, men i nero får jeg bare opp 23:16:37 #17 Phase 36 File dlgbrnst.cpp, Line 1762 Burn process started at 24x (3 600 KB/s) 23:16:37 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2721 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 23:16:37 #19 Text 0 File MMC.cpp, Line 17687 StartDAO : CD-Text - Off 23:16:37 #20 Text 0 File MMC.cpp, Line 22363 Set BUFE: Super Link -> ON 23:16:37 #21 Text 0 File MMC.cpp, Line 17915 CueData, Len=32 41 00 00 14 00 00 00 00 41 01 00 10 00 00 00 00 41 01 01 10 00 00 02 00 41 aa 01 14 00 00 19 47 23:16:37 #22 Text 0 File ThreadedTransfer.cpp, Line 269 Pipe memory size 74390400 23:19:37 #23 SPTI -1114 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1114) Sense Key: 0x06 (KEY_UNIT_ATTENTION) Sense Code: 0x29 Sense Qual: 0x00 CDB Data: 0x2A 00 FF FF FF 6A 00 00 20 00 00 00 Sense Area: 0x70 00 06 00 00 00 00 0A 00 00 00 00 29 Buffer x0664d040: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23:19:37 #24 CDR -1114 File Writer.cpp, Line 303 Reset occurred E: TSSTcorp CD/DVDW TS-L532A 23:19:42 #25 SPTI -1135 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00 Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C 23:19:42 #26 CDR -1135 File WriterStatus.cpp, Line 162 Write error E: TSSTcorp CD/DVDW TS-L532A 23:19:42 #27 TRANSFER -24 File WriterStatus.cpp, Line 162 Could not perform end of Disc-at-once 23:19:43 #28 Phase 38 File dlgbrnst.cpp, Line 1762 Burn process failed at 24x (3 600 KB/s) 23:19:43 #29 Text 0 File SCSIPTICommands.cpp, Line 261 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 23:19:45 #30 Text 0 File Cdrdrv.cpp, Line 11185 DriveLocker: UnLockVolume completed 23:19:46 #31 Text 0 File SCSIPTICommands.cpp, Line 424 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Har akkurat lastet ned siste versjon av nero, så det skal nok ikke ha noe å si. Den begynner aldri å brenne på plata virker det som, for platen er like ok etter den kommer ut. Å da kan jeg gjøre et nytt forsøk. Har oppdatert til siste firmware og.. er det noen andre brenne programm som kan være vært et forsøk å teste å se om det funker? Log.txt
SelfDestructor Skrevet 31. mai 2007 Skrevet 31. mai 2007 er det noen andre brenne programm som kan være vært et forsøk å teste å se om det funker? 8745049[/snapback] Du kan jo bruke Windows's brennefunksjon. Bare da noen filer inn i CD-rom mappen og klikk på "Write these files to CD".
