Problemer med Lydkort?
Hei
Nå trenger jeg sårt hjelp her altså... :cry: Hver gange jeg enten spiller, eller hører på musikk/film så henger pc`n seg... Har fått "bluescreen" 1 gang
A problem has been detected and windows has been shutdown to prevent damge to your computer
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this is the first time you've seen this stop error screen restart your computer. If this screen appears again, follow these steps.
Check to make sure any new hardware or software is properly installed. this is a new installation ask your hardware or software manufacturer for any windows upadate you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable
BIOS memory options such as caching or shadowing.
Technical Information:
*** STOP: 0*000000D1 (0*00000000, 0*00000002, 0*00000000, 0*F73881E3)
*** ALCSWDM.SYS - ADDRESS F73881E3 base at F7353000, DateStamp 428b0fe4
Beginnig of Physical Memory Dump
Noen som vet hva jeg kan gjøre? Har prøvd ALT som er, lastet ned nyeste driver, slettet de gamle, lagt inn nye...! Desperat her.. :mad:
Hjelp hjelp!!
prøvd å oppdatere windows??nyeste oppdateringer?!?!
8161145[/snapback]
Vel, tror det? Er ikke så veldig datakyndig så... :roll:
