Feil melding i dvd shrink
griped
hei og ja, har lest gjennom ganske mange poster angående dvd shrink feilmeldinger men ingen har egentlig hjulpet meg. så at nero 6.6.1.4 hadde noe imot dvd shrink men jeg har 6.6.0.15h så er det noe med nero å gjøre? i feilmeldingen står det:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 11:54:32
NT-SPTI used
Nero API version: 6.6.1.4
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 1, 4d
Recorder: <SONY DVD RW DW-G120A> Version: MYS2 - HA 1 TA 0 - 6.6.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD3000JS-00PDB0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SONY DVD RW DW-G120A atapi Port 3 ID 0 DMA: On
CdRomPeripheral : JY3419F FAW492Z 1.0 dtscsi Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
SONY DVD RW DW-G120A F: CDRom0
JY3419F FAW492Z J: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1022MB (1046956kB)
Free physical memory: 469MB (480936kB)
Memory in use : 54 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
18.12.2006
NeroAPI
21:15:14 #1 Phase 112 File APIProgress.cpp, Line 275
DVD-Video files reallocation started
21:15:14 #2 Phase 114 File APIProgress.cpp, Line 275
DVD-Video files reallocation completed (no file modified)
21:15:14 #3 Phase 111 File APIProgress.cpp, Line 275
DVD-Video files sorted
21:15:14 #4 NEROAPI 7 File Burncd.cpp, Line 3095
Error:\nCannot connect TRF.
21:15:14 #5 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
21:15:14 #6 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 27.07.2006 18:28:33 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
noen som har peiling?
