R10 VS Herosim-Warrior
Jeg samla inn litt info om de forskjellige settene.
Etter min mening er Heroism MYE bedre en R10 settet.
Jeg mener også at R10 settet er mye vasnkligere å få enn Heroism, Heroism settet skal jo være for "casual" gamers ikke sant?
Så, alt fra heroismt bortsett fra leggings vill jeg hatt, R10 leggings med 100+HP enchant eier :p
Legionnaire`s Plate Armor
+9 Strength
+6 Agility
+25 Stamina
Equip: Improves your chance to
get a critical strike by 1%.
Chestplate of Heroism
684 armor
+21 strength
+13 agility
+26 stamina
Equip: Improves ur chance to hit
by 1%.
Champion`s Plate headguard
534 Armor
+9 Strength
+8 Agility
+31 Stamina
Helm of Heroism
556 armor
+18 strength
+32 stamina
Champion`s Plate pauldrons
493 Armor
+7 Strength
+6 Agility
+23 Stamina
Spaulders of Heroism
507 armor
+12 strength
+12 agility
+18 stamina
Legionnaire`s Plate Legguards
575 Armor
+7 Strength
+13 Stamina
Equip: Improves your chance to get
a critical strike by 2%.
Legplates of Heroism
601 armor
+25 strength
+11 agility
+16 stamina
Equip: +5 defense
Blood Guard`s Plate Gloves
410 Armor
+16 Strength
+15 Stamina
Equip: Hamstring rage cost reduced
by 3.
Gauntlets of Heroism
393 armor
+18 strength
+12 stamina
Equip: Improves your chance to get a critical
strike by 1%.
Blood Guard`s Plate Boots
452 Armor
+8 Strength
+5 Agility
+23 Stamina
Boots of Heroism
470 armor
+20 strength
+20 stamina
Equip: Improves your chance to hit
by 1%.
R10 Set bonus:
2: Increases your chance to parry an attack by 1%.
4: Reduces the cooldown of your Intercept ability by 5 sec.
6: +15 Stamina.
Heroism Set bonus:
2:+8all resists
4:On melee hit heals you for 83 - 103 hps
6:+40ap
8:+200armor
Som dere ser så har Heroism mye bedre stats en R10.
Noe jeg ikke liker, for R10 er ikke SÅ lett å nå, og hvertfall ikke for en casual gamer.
Så jeg synes Blizzard bør fikse litt på dette.
Amaran
hmm, skaff en bra group å start med å farme ubrs, start, scholo, alle de plassene der valor dropper, da kan det gå ganske fort.
Å jeg har hørt at du ikke trenger de gamle delene, du trenger bare å gjøre et quest, men er jo ikke 100% sikker.
uansett, R10 sette blir liksom ubrukelig compared til dette sette, tviler på at noen kommer til å bruke R10 settet vis de kan få dette lett, noen kommer kansje til å bruke d som showoff ellerno(Horde), men ikke i PvP.
5746970[/snapback]
Du trenger alle delene, og dessuten er questene forå oppgradere delene til heroism et helvette.
5746970[/snapback]
5747031[/snapback]
Har du link til dem? Så jeg vet hva jeg eventuelt må samle inn etc.
altså, tier0 setter får man jo så og si av seg selv ettersom man kommer opp i lvl 55-60 og gjør et par instancer hver dag. da får man jo settet når man gjør vanlige quests.....
Jeg vil nok tro at Blizzard kommer til å oppgradere Rank10 armor. Det har lenge vært omtalt som litt "gammelt". Jeg skal nok få grindet meg til rank 10 og kjøpe armoren...så er det bare et spørsmål om tid før jeg ser at den er oppgradert:)
Uansett så ser rank10 armor utrolig mye kulere ut på en human warrior enn heroism gjør. Personlig har jeg aldri likt dem "amerikansk fotball skuldrene" som er en del av valor.
for min del er det nok lettere å oppnå rank10 enn å grinde til tier 0 da jeg har store problemer med å låse meg for noen timer av gangen liksom. I pvp BG's er det ingen som bryr seg om man pluttselig er ti min afk. I instanser vil slikt føre til kick og dårlig rykte.
Endret av gamer73
5746970[/snapback]
5747031[/snapback]
5747086[/snapback]
Nei, men jeg har begynt på de på test-serveren.
5748342[/snapback]
Altså, du kan ikke gå AFK i BG`s ;)
5747031[/snapback]
vis det hadde vært et helvette å få tingene hadde hele poenget vært borte, dette settet skal jo være for casual gamers, sånne som spiller 1-2 timer hver dag :S
eller?
Self kan man det:) detter man ut så detter man ut..ingen som bryr seg om det:)
5748585[/snapback]
haha ^^ /afk eller bare være afk, får ikke akuratt mye repeller honor av å bare stå der liksom.
EDIT: btw, når du da detter ut, skal du da vente i 15 min pga deserter buff, så gå AFK i 5 min til? hehe tjener sikkert enormt mye honor xD
Endret av Amaran
afk er bare en fellesbetegnelse på når man er borte fra pc'en..
Jeg hevder jo ikke at jeg kun går inn i BG's for å gå afk gjør jeg? Men hender det så betyr det svært lite i forhold til instance raid. Trodde dere tok poenget fra start av men men.. :ermm:
5748773[/snapback]
ja jeg gjorde det, men sjønner ikke at du kan gå AFK i BG, du får faktisk 0 honor.
Du må ha tagga en player for å få honor av den playeren vis han dør, vis du bare er afk der liksom så blir det svært lite honor.
Endret av Amaran
