riktig build for min warrior?
er snart lvl 60 med min warrior har ikke speccet noen talents enda. ville vente til lvl 60. er dette er bra build? eller noen som kan ambefale en annen? vill være en warrior som er bra i mc mot onyxia og diverse instances.
Saved Template
Class: Warrior
Level: 60
Arms Talents (20 points)
Deflection - 5/5 points
Increases your Parry chance by 5%.
Improved Rend - 3/3 points
Increases the bleed damage done by your Rend ability by 35%.
Improved Heroic Strike - 1/3 point
Reduces the cost of your Heroic Strike ability by 1 rage point.
Improved Thunder Clap - 3/3 points
Increases the damage done by your Thunder Clap by 25%.
Improved Charge - 2/2 points
Increases the rage generated by your Charge ability by 6.
Deep Wounds - 3/3 points
Your critical strikes cause the opponent to bleed, dealing 60% of your melee weapon's average damage over 12 seconds.
Improved Overpower - 1/2 point
Increases the critical strike chance of your Overpower ability by 25%.
Impale - 2/2 points
Increases the critical strike damage done by your abilities in Battle, Defensive, and Berserker stance by 20%.
Fury Talents (31 points)
Cruelty - 5/5 points
Increases your chance to get a critical strike with melee weapons by 5%.
Improved Demoralizing Shout - 5/5 points
Increases the attack power reduction of your Demoralizing Shout by 25%.
Unbridled Wrath - 5/5 points
Gives you a 40% chance to generate an additional Rage point when you deal melee damage.
Piercing Howl - 1/1 point
Causes all enemies near the warrior to be dazed for 6 seconds.
Enrage - 5/5 points
Gives you a 40% melee damage bonus for 4 swings any time you are the victim of a critical strike.
Death Wish - 1/1 point
When activated, increases your melee damage by 20% and makes you immune to fear, but lowers your defense against all types of damage by 20%. Lasts 30 seconds.
Improved Intercept - 2/2 points
Reduces the cooldown of your Intercept ability by 10 seconds.
Improved Slam - 1/5 point
Decreases the casting time of your Slam ability by 0.1 seconds.
Flurry - 5/5 points
Increases your attack speed by 30% for your next 3 swings after dealing a critical strike.
Bloodthirst - 1/1 point
Activates after dealing a killing blow. Your next melee weapon attack deals a 100% increased damage.
Protection Talents (0 points)
None
er du snart lvl 60 og har ikke brukt NOEN talent points ?? :ohmy: .
vet det er litt OMG men ville vente litt til lvl 60 fordi man har ikke samme erfaring i low lvl.. vill jo ha min warrior så best som mulig
Ja og så koster det jo hele 1 gull å forandre på builden også...
Hele 5 gull neste gang, så 25 gull derigjen...
Man pleier jo ikke ha noe særlig gull rundt 60.
Jeg skal ikke dømme deg, har sett mange som også har gjort som deg. Men de hadde skrudd av "help" funksjonen og var ikke klar over at det fantes noe som het talentpoints...
Skulle ønske noen kunne forklare meg hvorfor man IKKE skal bruke talentpoints etterhvert som man får dem, man kan jo bare bruke en end-game build som ligger ut og som man liker...
Edit: Kanskje du er "snart lvl 60" som i "Er for øyeblikket lvl 8 warrior, men skal spille hele helgen og regner med å lvl litt da..."?
Endret av Rookie_NO
du vet du kan respecce for en liten penge (som blir større etterhvert)?
Kjør en 31/20 Arms/fury spec.. Spec ned til MS og bruk TREIGE 2hånds våpen.. Du trenger ikkenoe spesiel spec om du skal Main tanke MC uanz.. Jeg kjører mye MC med 31/20 spec.. Main tanken vår som tanker Ragnaros har 31/20 Arms/Fury Spec..
koster bare 5 gull mer for hver gang.
sist gang betalte jeg 15 g for pallyen
5 g for roguen
og lvl 60 uten talents skjønner jeg ikke hvordan noen klarer, blir i hverfall ett kick når man får alle plutselig ;)
Det her er jo helt dumt og se på, om han har brukt talent points eller ikke er vell opp til han. Trenger ikke opp til 7 poster med kun klaging for at han ikke har brukt opp talent poengene hans.
Builden er sikkert helt grei men jeg ville brukt denne builden om jeg var deg, da er two-h axe en selvfølge som våpenvalg.
Fury Mastery
Cruelty Rank 5
Improved Demoralizing Shout Rank 5
Piercing Howl Rank 1
Improved Battle Shout Rank 4
Enrage Rank 5
Fury Total:20
Arms Mastery
Deflection Rank 2
Improved Rend Rank 3
Improved Charge Rank 2
Tactical Mastery Rank 5
Improved Overpower Rank 2
Deep Wounds Rank 3
Two-handed Weapon Specialization Rank 3
Impale Rank 2
Axe Specialization Rank 5
Sweeping Strikes Rank 1
Improved Hamstring Rank 2
Mortal Strike Rank 1
Arms Total:31
Total
Total Points Spent: 51
Level Required: 60
Håper dette hjelper deg litt. Lykke til.
Uhm, full deflection er _mye_ bedre enn lusne 2h spec ;)
Ellers er det vel standard cookie cutter build ;P
Endret av M@R7!N
Jepp det er det. Men den funker vell da greit og da. :)
Blir spennende og se på nye patch nå.
Du kommer nok til å få en overraskelse når du bruker talent points ja :!:
talent points utfgjør sikkert 70% av damagen til en warrior på level 60, med MS, 10% mer crit, enrage osv.
Nå var jo faktisk saken her at han ikke visste at han kunne respecce. Hadde han visst dette hadde han selvfølgelig brukt talentpoengene etterhvert som han fikk dem. Det må være lov å tulle litt med en som har prestert å komme til lvl 60 uten å ha fått med seg dette... Det sier vel litt om hvor enkelt det er, bare man har nok tid...
Amd-Barton : Jeg er ganske sikker på at det koster 5 ganger så mye hver gang man respeccer. Det var i hvertfall slik før, mulig det er forandret i en patch, men det tviler jeg på... (Altså blir det seende slik ut : 1-5-25-125-625 osv...)
Om du er en av de som kommer fra Diablo2 verdenen så skjønner jeg at du ikke ville bruke de (der kunne du ikke specce om).
Men som warrior, så har du to valg (etter min mening)
Arms/fury
31 arms, helt ned til mortal strike, da dette er den _beste_ pvp/solo abiliten til en warrior.
Resten plassere du i fury, få med deg cruelty der, så du har 5% ekstra critt.
I arms så er de viktigeste(etter min mening)
Tactical mastery (5/5)
Anger Mangment (1/1)
axe spec (5/5)
deep wounds (max husker ikke nå)
impale (max for mere critt skade)
Sweeping strikes (1/1) for å kunne få Mortal strike
Den andre er prot specced warrior
Du trenger da, parry, tactical mastery og angermanagment i arms
evt kan du ta cruelty i fury
mens resten tar du i protection.
Protection treet, dog litt (veldig) dårlig om du er mye alene, evt vil pvp'e
Gjør at du holder aggro bedre, resiter en del stun/charm effekter, samt får bedre ac og blokk skills.
Som siste mening så har du en "hybride" build (jeg kjører denne)
31 arms/5 fury/15 protecton
Her har jeg beholdt pvp delen, men fått på sheil specialistion, iron will, thoughness osv, slik at jeg kan hive på alt +def/sta/strength gearet mitt og være en bedre tank, og ta på meg agi/sta/str/+%crit gearet om jeg skal spille solo og pvp'e
men dette er bare min mening. ligger masse guider til dette rundt om, og det finnes en talent kalkulator på ign sine sider (google på wow talent builder)
\\Sp33D
BTW så tror jeg respecc caper på 50gp
Denne linken har blitt postet før, syns det han sier virker veldig fornuftig, sjekk også for våpenvalg.
En ting jeg lurer på her, er foresten om det lønner seg og ta et point fra hamstring, og sette i percing howl?
Endret av guttorm
