SilverCRX Skrevet 3. juni 2005 Skrevet 3. juni 2005 (endret) Nå er snart tiden inne for MC-runs, og da er det som kjent på tide å respecce litt Noen som har litt erfaring som kan kommentere denne builden? (Merk: Builden er laget spesifikt for Onyxia/MC, men noen av elementene velges av personlige preferanser) Arcane Talents (28 points) Improved Arcane Missiles - 5/5 points Gives you a 100% chance to avoid interruption caused by damage while channeling Arcane Missiles. Arcane Concentration - 5/5 points Gives you a 10% chance of entering a Clearcasting state after any damage spell hits a target. The Clearcasting state reduces the mana cost of your next damage spell by 100%. Improved Arcane Explosion - 5/5 points Reduces the casting time of your Arcane Explosion by 1.5 seconds. Evocation - 1/1 point While channeling this spell, your mana regeneration is active and increased by 1500%. Lasts 8 seconds. Improved Counterspell - 2/2 points Gives your Counterspell a 100% chance to silence the target for 4 seconds. Arcane Meditation - 5/5 points Allows 15% of your Mana regeneration to continue while casting. Presence of Mind - 1/1 point When activated, your next Mage spell with a casting time less than 10 seconds becomes an instant cast spell. Arcane Mind - 4/4 points Increases your maximum Mana by 8%. Frost Talents (23 points) Improved Frostbolt - 5/5 points Reduces the casting time of your Frostbolt spell by 0.5 seconds. Permafrost - 5/5 points Increases the duration of your chill effects by 3 seconds. Winter's Chill - 3/3 points Increases the power of your chill effects by slowing the target's movement by an additional 10%. Cold Snap - 1/1 point When activated, this spell finishes the cooldown on all of your cold spells. Improved Blizzard - 3/3 points Adds a chill effect to your Blizzard spell. This effect lowers the target's movement speed to 35% of normal. Lasts 1.50 seconds. Arctic Reach - 2/2 points Increases the range of your Frostbolt spell and the radius of your Frost Nova and Cone of Cold spells by 20%. Frost Channeling - 3/3 points Reduces the mana cost of your frost spells by 15%. Ice Block - 1/1 point You become encased in a block of ice, protecting you from all physical attacks and spells for 10 seconds, but during that time you cannot attack, move, or cast spells. Fire Talents (0 points) None Takker på forhånd for svar Edit: kan være greit å nevne at min main holder til på en PvE-server, så crit-gear og andre typiske PvP-elementer utelukkes, og vil ikke bli brukt. Hovedformålet for denne builden er CC, survival og aggro-control (ikke ute etter noen 5x chain-crit som gjør livet ekstra surt for MT ). Mana conservation er den røde tråden i builden, og gear til denne vil være rent INT/SPI-fokusert med mana regen egenskaper. Bortsett fra resist-gear, så klart. Endret 3. juni 2005 av SilverCRX
chokke Skrevet 3. juni 2005 Skrevet 3. juni 2005 hvorfor ha mindre sjanse for å bli forstyrra i arcane missiles?
fenris1911 Skrevet 3. juni 2005 Skrevet 3. juni 2005 Eg har ein 33/18 frost/arcane build på ein annan pc som sikkert kan vere interessant for deg. Viss du er interessert kan eg poste den seinare.
OscarWoHA Skrevet 3. juni 2005 Skrevet 3. juni 2005 hvorfor ha mindre sjanse for å bli forstyrra i arcane missiles? Blir man 'forstyrra', er man død uansett
chokke Skrevet 3. juni 2005 Skrevet 3. juni 2005 hvorfor ha mindre sjanse for å bli forstyrra i arcane missiles? Blir man 'forstyrra', er man død uansett så du mener også det er unødvendig?
SilverCRX Skrevet 3. juni 2005 Forfatter Skrevet 3. juni 2005 Imp. Arcane Missiles har jeg kun brukt talent points på for å kunne komme lenger ned på Arcane-treet. Rett og slett fordi de andre valgene er totalt ubrukelige, mens IAM kan være nyttig i rett situasjon (er fullt klar over at den er ubrukelig i MC, siden AM sikter på hodet til mob'en og man da må stå _veldig_ mye nærmere enn hva man må med f.eks frostbolt)
Krims Skrevet 3. juni 2005 Skrevet 3. juni 2005 Jeg ville satsa en nesten full frost build, men ikke så mye på frost at du ikke får PoM.
Lacim Skrevet 3. juni 2005 Skrevet 3. juni 2005 Unødvendig å specce frost bare for MC. Mages er ikke primært dps i MC.
Plomma2 Skrevet 4. juni 2005 Skrevet 4. juni 2005 På luci er vi i alle fall bare curse dispellere når addsa hans er døde.
Raugen Skrevet 4. juni 2005 Skrevet 4. juni 2005 Cure? er det noe jeg har gått glipp av de siste 42 lvl'ene? Jeg kan bare komme på Remove Lesser Curse
