Shaman talent tree
Hei,
Jeg har nettopp parkert min human warrior til fordel for en troll shaman. Har lekt meg litt med talent kalkulatoren på denne siden: http://wowvault.ign.com/View.php?view=Talents.View
Dette er det første oppsettet jeg føler meg noen lunde komfortabel med:
Elemental Combat Talents (31 points)
Improved Lightning Bolt - 5/5 points
Reduces the Mana cost of your Lightning Bolt spell by 15%.
Concussion - 5/5 points
Increases the damage done by your Shock spells by 5%.
Convection - 5/5 points
Reduces the Mana cost of your Shock spells by 10%.
Reverberation - 5/5 points
Reduces the cooldown of your Shock spells by 1 second.
Call of Thunder - 5/5 points
Increases the critical strike chance of your Lightning spells by 6%.
Improved Fire Nova Totem - 2/2 points
Reduces the delay before your Fire Nova Totem activates by 2 seconds.
Improved Magma Totem - 2/2 points
Reduces the Mana cost of your Magma Totem by 20%.
Elemental Fury - 1/1 point
Increases the critical strike damage done by your Fire, Frost, and Nature spells by 100%.
Elemental Mastery - 1/1 point
When activated, this spell gives your next Fire, Frost, or Nature damage spell a 100% critical strike chance.
Enhancement Talents (20 points)
Ancestral Knowledge - 5/5 points
Increases your maximum Mana by 5%.
Thundering Strikes - 5/5 points
Improves your chance to get a critical strike with your weapon attacks by 5%.
Improved Ghost Wolf - 2/2 points
Reduces the cast time of your Ghost Wolf spell by 2 second.
Two-Handed Axes and Maces - 1/1 point
Allows you to use Two-Handed Axes and Two-Handed Maces.
Improved Strength of Earth Totem - 2/3 points
Increases the amount of Strength raised by your Strength of Earth Totem by 10%.
Flurry - 5/5 points
Increases your attack speed by 30% for your next 3 swings after dealing a critical strike.
Restoration Talents (0 points)
Har valgt å ikke ta bruke noen poeng på healing. Det er ikke det jeg ønsker å bruke shaman min til.
Har kallt personen min Fira så jeg kunne tenkt meg å bruke flere poeng på fire for å få det rette imaget ;) , men da må jeg enten ofre Flurry eller en del av shock spell talents. Vil Call of Flame (fire damage +10%) eller Improved Searing Totem (searing totem duration +20%) veie opp for enten litt mindre shock spell damage eller flurry?
Jeg satser på meele combat med min shaman, så disse talents har jeg valgt hittil:
Elemental Combat Talents (11 points)
# Concussion - 5/5 points
# Convection - 5/5 points
# Elemental Focus - 1/1 point
Gives you a 10% chance to enter a Clearcasting state after casting any Fire, Frost, or Nature damage spell. The Clearcasting state reduces the mana cost of your next damage spell by 100%.
Enhancement Talents (23 points)
# Ancestral Knowledge - 5/5 points
# Thundering Strikes - 5/5 points
# Improved Lightning Shield - 3/3 points
Increases the damage done by your Lightning Shield orbs by 15%.
# Improved Ghost Wolf - 2/2 points
# Flurry - 5/5 points
# Parry - 1/1 point
Gives a chance to parry melee attacks.
# Improved Windfury Weapon - 2/2 points
Increases the Attack Power bonus of your Windfury Weapon effect by ?.
# None
Det jeg lurer mest på er:
Er det verdt å ofre 7 poeng på Shock spells eller Flurry og et par poeng til på encancement for å få Call of Flame og Improved Searing Totem?
Har enda ikke opplevd at totemet blir borte før kampen er ferdig når det er 1vs1. Dersom det er flere som slåss bruker jeg magmatotem.
Searing totem og stoneclaw totem er de mest ubrukelige shaman spell'ene syns jeg, men tror det har mye med spillestilen å gjøre.
Stoneclaw er fint for å slippe unna mobs.
Blir du aggroa mens du løper på tvers av Barrens, drop stoneclaw, og vips du slipper en encounter...
Eller du dropper earthbind, som hjelper mot både players og beasts.
Restoration linja har et spell som heter nature swiftness....
Lar deg insta kaste et spell. Improved lesser healing ward er også et genialt spell i pvp :) Så ikke tro at det å plasere points i healing er bortkastet.
Jeg tror egentlig at du kan drite i å improve lightning bolten.
Jeg bruker den utrolig sjeldent, og når jeg bruker den er det bare for å pulle.
Hadde det vært mindre casting time hadde det aknskje vært verdt det, men at det koster mindre mana hjelper ikke så mye egentlig...
