Endre passord i D-link?
Har en D-link 624, som ikke har vært i bruk på lenge. Så lenge at jeg har rota bort passordet for admin. Har hørt det skal være en mulighet for å slette det, med å trekke ut kontakter e.l. Vet noen hvordan dette gjøres? Prøvd support til D-link, men der var det ikke lett å komme til.....
What can I do if I forgot my password?
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
