Vil dere ha bedre A.I i Battlefield Vietnam ?
Nå lages det en egen mod for botene i spillet:
Our very own Dnamro is holding an open beta for the BFV version of the RealPlayer mod. If you're interested then grab the mod here and after you've tested it make sure to give him some feedback in the fourm to help make the mod even better.
Here's some more info about the mod:
Realplayer Battlefield Vietnam is a single player/coop enhancement mini-mod.
This is an open source mod. Other mod teams are welcome to use the AI improvements for their own mods.
The mod contains several bug fixes and changes to improve the single player/coop experience.
To install - just extract the installer from zip file and run.
To play - start the game from the Realplayer vietnam icon or select realplayer from the custom game menu.
1.e:
- Specialized bot names on all maps
- Maximized attack and aggression on all maps. Some maps were maxed out by DICE. Maps improved by RealPlayer:
Hoci. Trail
Cambodia
Hue
Reclaim Hue
IA Drang
Khe Sahn
Op. Irving
Previous -
- Added Realplayer AIbehaviors for more aggressive bots.
- Medpacks are enabled for bots and added to most classes.
- The wrench is fixed for bot use.
- Third person soldier view added.
- Gun camera tweaked on most vehicles.
- Several vehicle AI bugs fixed ( such as gunner on helicopter).
- Bots capability to fire from passenger postion added to BTR60 and Samapan.
- Bots tendency to bail from pilot postion of helicopters was reduced.
- Bot weapon ranges overall are increased.
- Bots will use grenades against vehicles.
- Smoke grenade replaced with standard grenade.
- Bots will prefer to use rocket weapons against vehicles and change to another weapon to attack infantry.
This is a combined project with Necronom and Dnamro.
Download: http://www.fileplanet.com/dl.aspx?/planetb...ayers/rpv1e.zip
Og A.I`en i spillet vil stadig øke ettersom patchen blir nyere og nyere. Har ikke testa den, men jeg vet at enkelte her synes at single player er litt viktig så dere kan få prøve den.
Gjerne legg inn noen kommentarer. :)
Jeg sa ikke at single player i dette spillet var så stor hitt i dette spillet, men enkelte synes at LAN med boter er gøy og det er det også om botene er gode.
Så bare prøv denne modden om dere ønsker.
+ at enkelte ikkje har tilgang til internet eller "raske" linjer..
Det også.
Jeg synes IKKE at det skal være et krav hos mange at de må ha internett for å kunne nyte et godt spill som dette.
Så jeg synes det er bra noen lager egne mods til å forbedre A.I`en, den gjør LAN gameplayet mye mere morsomt også.
Har lastet ned men klarer ikke å bruke den. Noen som kan forklare hvor jeg skal legge den, hvordan starte osv?
Er det som stod i readme.txt værtfall.
Så langt er dette bare en beta mod.
Ny verson kommer denne uka.
Greit om noen har lyst å teste for å så komme med litt feedback om hva dere synes:)
kan sikkert prøve dem jeg når dem kommer ut
Funker fint så langt som jeg har sett. Har ikke hatt tilfeller av at AI gutta har hoppet ut av pilotsetet enda. Opplever også at fienden kommer i kopter med 4-5 soldater som hopper ut i fallskjerm og faktisk gjør et forsøk på å angripe. Fin mod. den gjør faktisk BFV til et akseptabelt SP spill
Jeg fatter egentlig ikke hva som egentlig er "forbedringene" fra BF42 til BFV??
I mine øyne er botene dummere enn de originale BF42. Mange ganger har jeg sett bot'er som bare sitter rolig i et kjøretøy. Man kan da gå helt bort og sette pistolen mot skallen deres og avlive dem raskt og problemfritt. De merker ikke at du står der engang!
Slikt skjedde da aldri i BF42.
Nettop, og på intervjuene var de så flinke og skryte av ai`en.
eg får ikkje lasta den ned. eg får bare beskjed om å logge inn. men eg er logga inn (så vidt eg veit) er det nokon andre plasse der eg kan laste den ned?
eg har gratis konto.
Rart =/
Her funker det knall.
Tror fileplanet er det eneste stedet så langt, men skan jo si i fra om jeg finner et annet sted.
