Opera->wand
Noen som vet hvor den wand en kan skrues av?(Bruker versjon
7.10 )
Er sinnsykt irriterende, dessuten så funker den ikke heller... :(
Dette hadde du funnet ved å søke litt i Operas hjelpefiler: :)
If you do not wish to use the Wand, it is possible to disable it:
Go to Help > About Opera and find the "Preferences" path which points to the correct Opera6.ini file
Close Opera and open the above Opera6.ini file in a text editor
Find the [user Prefs] section of the file and add the following line to disable the Wand:
Enable Wand=0
