Trenger hjelp med Arch
Har flere spørsmål og problemer, så de kommer fortløpende i denne tråden. :p
1. Får error når jeg kjører pacman -Syu:
$ sudo pacman -Syu
:: Synchronizing package databases...
core is up to date
extra is up to date
community is up to date
unstable is up to date
archlinuxfr is up to date
proaudio is up to date
:: Starting full system upgrade...
warning: iproute: local (070710-1) is newer than core (2.6.24_rc7-1)
resolving dependencies...
looking for inter-conflicts...
Targets: attr-2.4.41-1 acl-2.2.47-1 diffutils-2.8.1-5 gawk-3.1.6-2
m4-1.4.11-1 autoconf-2.62-1 automake-1.10.1-2
bcm43xx-fwcutter-006-2 bin86-0.16.17-3 binutils-2.18-6 bison-2.3-4
bridge-utils-1.2-2 bzip2-1.0.5-2 capi4k-utils-050718-6
cracklib-2.8.10-5 pam-1.0.1-1 shadow-4.0.18.2-2 coreutils-6.11-1
cpio-2.9-3 device-mapper-1.02.24-1 e2fsprogs-1.40.8-1
libgpg-error-1.6-1 libgcrypt-1.4.0-1.1 popt-1.10.6-3
cryptsetup-1.0.6-1 dcron-3.2-3 dhcpcd-3.2.1-1 ncurses-5.6-6
dialog-1.1_20080316-3 dmapi-2.2.8-3 openssl-0.9.8g-2
dnsutils-9.4.2-1 dosfstools-2.11-2 ed-0.9-1 filesystem-2008.03-2
grep-2.5.3-3 sed-4.1.5-3 fakeroot-1.9.3-1 zlib-1.2.3-4
file-4.24-1 findutils-4.2.33-1 flex-2.5.33-4 gmp-4.2.2-2
mpfr-2.3.1-1 gcc-4.3.0-1 gdbm-1.8.3-5 gen-init-cpio-2.6.17-3
gettext-0.17-1 gnome-keyring-2.22.2-1 gpm-1.20.3-1 groff-1.19.2-4
grub-0.97-12 gzip-1.3.12-4 hdparm-8.6-1 hwdetect-0.9-1
ifenslave-1.1.0-3 net-tools-1.60-13 initscripts-2008.05-1
iptables-1.4.0-2 iputils-20070202-4 wireless_tools-29-2
ipw2100-fw-1.3-2 ipw2200-fw-3.0-2 ipw3945-ucode-1.14.2-2
ipw3945d-1.7.22-4 klibc-1.5-5 klibc-extras-2.4-1 klibc-udev-116-3
klibc-module-init-tools-3.2.2-3 kbd-1.14.1.20080309-2
klibc-kbd-1.15.20080312-5 mkinitcpio-0.5.19-1
module-init-tools-3.2.2-6 kernel26-2.6.25.4-1 ipw3945-1.2.2-10
isdn4k-utils-3.2p1-3 iwlwifi-3945-ucode-2.14.1.5-2
iwlwifi-4965-ucode-4.44.1.20-1 jfsutils-1.1.12-2 less-418-1
libelf-0.8.10-3 libevent-1.3e-1 libsasl-2.1.22-5 libldap-2.3.40-1
libpcap-0.9.8-2 libusb-0.1.12-3 licenses-2.4-1 lilo-22.8-2
logrotate-3.7.5-1 lvm2-2.02.36-1 lzo2-2.02-3
madwifi-utils-0.9.4.3382-1 madwifi-0.9.4.3382-5 mailx-8.1.1-5
make-3.81-3 man-1.6f-2 man-pages-2.79-1 mdadm-2.6.4-1
nano-2.0.7-1 ndiswrapper-utils-1.52-1 ndiswrapper-1.52-4
netkit-telnet-0.17-7 nfsidmap-0.20-2 portmap-6.0-2
tcp_wrappers-7.6-8 nfs-utils-1.1.0-4 ntfs-3g-1.2506-1
ntfsprogs-2.0.0-2 openssh-5.0p1-1 openswan-2.4.11-1
openvpn-2.0.9-3 patch-2.5.9-1 sysfsutils-2.1.0-4 pcmciautils-014-4
pkgconfig-0.23-1 ppp-2.4.4-6 pptpclient-1.7.1-3 procinfo-19-2
procps-3.2.7-4 psmisc-22.6-1 readline-5.2-7 reiserfsprogs-3.6.20-3
rp-pppoe-3.8-3 rt2500-1.1.0_B4-23 screen-4.0.3-5 sdparm-1.02-2
syslog-ng-2.0.6-1 util-linux-ng-2.13.0.1-2 sysvinit-2.86-4
tar-1.20-2 vi-7.1.267-1 vpnc-0.5.1-2 wget-1.11.2-1 which-2.19-2
wlan-ng26-utils-0.2.8-2 wlan-ng26-0.2.8-17 wpa_supplicant-0.5.10-1
xfsprogs-2.9.7-1 xfsdump-2.2.46-3 xinetd-2.3.14-3
zd1211-firmware-1.4-2
Total Download Size: 0,00 MB
Total Installed Size: 296,97 MB
Proceed with installation? [Y/n] y
checking package integrity...
(141/141) checking for file conflicts [#####################] 100%
error: could not prepare transaction
error: failed to commit transaction (conflicting files)
gpm: /usr/lib/libgpm.so.1 exists in filesystem
Errors occurred, no packages were upgraded.
Hvordan løser jeg dette?
Endret av Xecuter88
Ah! Takk!
2. Teite ting med pacman. (Eller ikke akkurat pacmans feil):
"pacman -S firefox3" installerer Firefox 3 beta, men det fins ingenting i systemet som heter firefox3 eller liknende.
Samme med hdparm, installerer det, men kommandoen hdparm fins ikke.
Og, hvordan får jeg bokmerkene mine i Ubuntu til Arch?
Endret av Xecuter88
Ah! Takk!
Kan hende de blir lagt til et sted i $PATH du ikke har prøv 'source /etc/profile', hvis det funker er det ikke mer å tenke på og det vil funke automagisk neste gang du logger inn. Hvis ikke kan du jo se på hva som er installert med f.eks pacman -Ql firefox3 og sammenligne det med echo $PATH.
Sjekk om du har en /etc/profile.pacnew. Hvis du ikke har endret noe manuelt i profile, burde det gå greit å bare kopiere profile.pacnew til profile (Ta gjerne backup av profile før du gjør det). Jeg mener å huske det var noe styr med $PATH og profile for en tid tilbake.
Både firefox og opera har import/export-funksjonalitet for bokmerker.
I Firefox 3; Bookmarks -> Organize Bookmarks -> Import and Backup
Takk takk! :D
3. Har problemer med å montere ting med hal. Virker rett og slett som et eierskap-problem siden det fungerer å montere diskene med "sudo mount".
Ah kjekt!
Leste litt rundt og fant ut at jeg måtte være i optical-gruppen for å kunne se DVD-er o.l., så jeg la meg til der også.
Først fikk jeg beskjed om at udf-filsystemet ikke støttes av systemet, og kunne ikke lese av DVD-en. Så jeg prøve å restarte hal og dbus, men nå starter ikke Gnome korrekt. :wee:
Dvs, jeg har ingen skrivebord, eller menyer, ingen snarveier fungere, osv. Hvordan i h får jeg fikset dette da?
Fiksa det.
4. En ting jeg savner fra Ubuntu er autocompletion i pacman; at jeg kan skrive "sudo pacman -S somepack<tab>" og så fullfører navnet seg, eller en liste med valg kommer opp. Kan dette gjøres?
Husker ikke hvor jeg fant ut hvordan jeg gjorde det. Men det funker. Lurer på om det var HER løsninga var.
Tror du må benytte deg av ZSH fremfor BASH og installere pacman-zsh fra aur.
bash-completion gir deg autofullføring av pacmankommandoer i BASH. Funker fint her, men har ikke testet om det virker med sudo.
brukte bash-completion før, og mener det fungerte med sudo. Mulig det var noe mikkmakk som skulle til. Du finner noe om det her.
Jeg snakker ikke om fullføring av pacman-kommandoer, men av pakkene i pakkesystemet! Det er en viss forskjell.
Kom på hva jeg skulle spørre om: Arch slår seg ikke av ved shutdown, den bare logger seg ut av Gnome og gdm, og faller tilbake til sh, deretter må jeg logge inn og skrive shutdown på nytt igjen. Hvordan fikser jeg?
Endret av Xecuter88
Det er det jeg snakker om også!
pacman -S bash-c [TAB]
pacman -S bash-completion
