Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /home/sinolsne/public_html/Mobstar/_ip_block.php on line 14
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /home/sinolsne/public_html/Mobstar/_ip_block.php on line 15
Disse meldingene kommer opp når man skal registrere seg, når man skal logge inn kommer denne meldingen:
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /home/sinolsne/public_html/Mobstar/_check_user.php on line 19
Hva skal jeg gjøre?
Vis oss koden din. Umulig å feilsøke uten den.
Edit: Er dette ditt eget prosjekt?
Ok, hvem kode skal du ha?
tenker du på den fila man "connecter" mysql med?
EDIT: Nei, ikke mitt ..
Endret av Sindre-91
Dersom det ikke er ditt prosjekt får du ta kontakt med webmaster el. lignende. Pleier som regel å stå oppgitt på siden.
Hviken side er det snakk om? Home.no?
/* This Code is FREE to usse! but leave this comment here for the effort...
@autor:W. Vellema
@site :http://vellema-coding.tk
@date :2 feb 2005
class Connect
function Connect()
if (!@mysql_connect("localhost","root","")) // Hostname,Username,Password,DatabaseNname
die ("<br />mysql_error() Reports: " . mysql_error() . "<br />");
else
//echo "\n<!-- Database connection established. -->";
if (!@mysql_select_db( "overhoor" ))
function End()
if (!mysql_close())
echo "\n<!-- Database Break Failure. -->";
else
echo "\n<!-- Database Break Succesfull. -->";
class sql
function query( $Query )
$Handle = mysql_query( $Query );
if (!$Handle)
echo "<font size=3 color=red><small>mysql_error() Reports <b>" . mysql_error() . "";
echo "</b><br />Query: " . htmlspecialchars($Query) . "</font>";
return FALSE;
} else {
$this->id = mysql_insert_id();
$this->queryLast = $Query;
$this->lastHandle = $Handle;
return TRUE;
function fetch($Query)
return mysql_fetch_array($Query);
function countRows($Query)
return mysql_num_rows( $Query );
function rows($Query)
if (mysql_num_rows ($Query) > 0) return true;
else return false;
Endret av Sindre-91
@autor:W. Vellema
@date :2 feb 2005
class Connect
function Connect()
else
function End()
if (!mysql_close())
else
class sql
if (!$Handle)
return FALSE;
} else {
return TRUE;
else return false;
1 ting og si
Spør heller de som har laget den scripten "http://vellema-coding.tk"
De som kan vite hva som er feilen
btw det skal være :
<?php
 @autor:W. Vellema
 @date :2 feb 2005
class Connect
function Connect()
	else
function End()
	if (!mysql_close())
  else
class sql
	if (!$Handle)
	return FALSE;
  } else {
	return TRUE;
	else return false;
Endret av Speedy610
