The Witcher. Førsteinntrykk og tips
Lønner det seg å ha patch 1.1a installert før man installerer 1.2?
Har ikke noe å si. Fra Readme-en:
You DO NOT need to install The Witcher Patch 1.1 in order to install 1.2 version.
ok. Takk :)
Endret av mr_tambourine_man
vart helt forelska i demoen. endevendte alle butikkane der eg bur etter the witcher, kun 1 hadde, og var utsolgt, resten hadde ikkje hørt om det:( kompis skal til bergen på lørdag, og tar med eit tilbake:D
Patch notes for 1.2 - mye bra her! Har ikke testet selv, men de sier at det blir vesentlig kortere loade- og savetid.
5a. Patch 1.2 Major Fixes
Gameplay and text bugs fixed:
- Fixes for Alina not being at her home when she should (Act 4).
- Wife's Tears Potion fixes.
- Fixes for usable doors on the swamps (Act 5).
- Fixes for Alchemist in manufacture giving quest items to Geralt (Act 3).
- Fixes for some items to be found in Fields (Act 4).
- Fixes for a disappearing enemy in quest Haunted House (Act2).
- Fixed problems with Alvin's spawn (Act 1).
- Few minor text fixes for all languages.
Code bugs fixed:
- Loading times are much faster!
- Saving is much faster!
- Another portion of stability improvements.
- Fix for rare "red rectangle" effect on loading bar.
- Quest tracking fixes.
- Some cursor fixes connected with finishers in tight places.
- Quest now won't update when Geralt is dead causing multiple problems.
- Autosave mechanism fixes (numeration).
- Savegame files fixes – some irrelevant information was sometimes generated inside.
- The game won't make an autosave if Geralt has an effect preventing him from talking (like knockdown, stun, push) - the result would be no talking at all for the rest of the game.
- Now you can't attack neutral NPCs if you input the second (etc.) sword sequence in them, while first attacking a hostile.
- Dandelion's music won't be 'echoed' while changing location twice.
- The game can handle broken savegames now – it returns to main menu.
- Motion blur effect won't stay active despite Blizzard potion wearing off – drinking, then changing location, then cutscene.
- Final fixes for weapons disappearing from enemies’ hands.
- Grass and small stones being multiplied – fixed.
- Fixes for receiving damage from Striga while being far away.
Art bugs fixed:
- Few level decoration fixes.
- Fixes for barghest attack animation.
Argh. Patch-installeren kræsjer med kryptisk feilmelding '>SetupNew\setup.cpp (135)...' hos meg. Hva er det med pc-utviklere og kvalitetskontroll om dagen? :(
Endret av thomanil
Ok, loadetidene når det f.eks. gjelder inn- ut av hus er MYE raskere. Herlig :thumbup:
Måtte du starte new game for at det skulle virke?
Nei. Fortsatte på de gamle savingene.
Helt utrolig. Hadde problem med den nye patchen, så jeg prøvde reinstall for å se om det hjalp. Nå etter reinstall nekter spillet til og med å starte i det hele tatt, kopibeskyttelsen tror ikke lenger at jeg bruker original-DVD. Og dette er med ærlig kjøpt spill, på en burk uten daemon tools eller annet "snusk" installert.
Er det rart folk driter i pc og hopper over til konsoll?
So long, jeg arkiverer Witcher og koser meg med Mass Effect istedet nå.
Endret av thomanil
