Warlock vs hunter i party
Regner med at du mener PvE damage og ikke PvP?
Kommer an på flere vilkår. Først og fremst hvem som sitter ved tastaturet, men også hvordan gruppa er bygget opp.
Jeg holder en knapp på warlocks, tror det er lettere å holde høy dps som warlock hvertfall, med hunter må man jobbe som en gal for det.
PS. Kommer antageligvis en hundter dps buff snart.
8358641[/snapback]
Hvor har du dette fra?
"hunter dps is being looked at" - sitat Ommra. Orker ikke å bla fram topic'en, men det ble vel sagt for en uke siden eller noe sånt.
Hvis patch notene som florerer er riktige, så har hunters fått en liten dps buff via pets og et par andre spec-avhengige abilities.
Klikk for å se/fjerne innholdet nedenfor
Hunters
- A new "Avoidance" ability can now be taught to hunter pets. This
effect reduces the damage they take from area of effect spells and
abilities.
- A new "Cobra Reflexes" ability can now be taught to hunter pets. This
effect increases attack speed but reduces damage.
- "Arcane Shot": Casting lower ranks of "Arcane Shot" than your maximum
rank will now reduce the bonus you receive from attack power.
- "Aspect of the Cheetah/Pack": Wand damage will again correctly daze
players with this effect active.
- "Clever Traps" now affects "Snake Trap".
- "Entrapment" (Survival): Effect duration reduced to 4 seconds and is
now subject to diminishing returns in PvP.
- "Entrapment": The tooltip has been corrected to indicate it works on
"Snake Trap".
- "Expose Weakness": The chance for this talent to trigger has
increased to 33/66/100% chance at 1/2/3 talent points.
- "Ferocious Inspiration": This ability will now trigger "Kill Command"
correctly.
- "Flare" cooldown increased to 20 seconds, and duration reduced to 20
seconds.
- "Frenzy": This talent can now trigger from "Kill Command".
- "Frost Trap": This trap no longer breaks stealth from its slowing
effect.
- "Go for the Throat" no longer causes additional threat.
- "Hunter's Mark": This ability now becomes stronger each time the
target is struck by a ranged attack.
- "Improved Hunter's Mark": Adjusted the tooltip to indicate this
talent only grants melee attack power equal to the base ranged attack
power on the "Hunter's Mark".
- "Kill Command" has been removed from the global cooldown. The shout
animation has been removed.
- "Readiness": Now resets the cooldown on "Misdirection".
- "Revive Pet": The tooltip has been adjusted to indicate the pet
returns with a percentage of its base health. It will not get an
increased percentage of the bonus health it receives from a
percentage of its master's stamina.
- "Scatter Shot": This ability will now trigger "Kill Command" when
it critically strikes.
- "Survival Instincts" now also increase attack power by 2/4%.
- The quest creature, Death Ravager, is no longer able to be tamed.
- The Razorfang Ravager can now be tamed.
- Hunter "Mend Pet"/"Improved Mend" Pet Changes:
Replaced the current "Mend Pet" channel spell with an instant cast
heal over time.
No combat reset, resets global cooldown
The mana cost has been reduced and the heal value increased.
Duration on Heal Over Time increased to 15 seconds in 3 second
increments.
Changed the graphic to better represent the Heal Over Time effect
on the pet.
The "Mend Pet" heal over time buff is now able to be dispelled.
Bonus healing gear will no longer effect "Mend Pet".
Added a 10% and 20% reduction to the mana cost of "Mend Pet" in
"Improved Mend Pet" talent (Beast Mastery).
edit: la til PTR patch notes
Endret av Rata101
Heisann!
Med omtrent jevnt gear, hvilken klasse burde gi mest dmg i party av hunter og full destruction lock?
Edit:
Har nemlig registrert at i party bestående av:
tank, hunter, paladin, lock og priest (alle på 70) så har huntern ca 50% av dmg, palla 25%, lock 20% og tank/priest resten.
Dette er samme gruppen hver gang (vennegjeng)
Lock sier han har crits opptil 5k.
8358555[/snapback]
Med tanken så lavt som 5% kan man likegjerne konkludere først som sist med at meteret ikke var synkronisert og tallene ikke er til å stole på. Tilfeldigvis hunteren som kjører meteret?
Noen klasser/builds har helt klart større dps potensialet enn andre, men med så store sprik som i målingen din er nok klassebalanse den minste faktoren.
har etter litt mer testing og chatting in-game kommet frem til at det var en kombinasjon av forskjellig versjoner av D. Meter og litt problemer fra locken sin side^^
Virker mer normalt nå, og alle har fått samme versjon av d.meter.
Takker for alle tilbakemeldingene
