Irriterende problem i spill!
For en uke siden, har jeg blitt disconnected fra så og si alle spill. På Day of Defeat Source og CounterStrike: Source står mannen min stille og alle de andre mennene fryser helt, dog jeg kan se rundt på skjermen. På BF2 får jeg Connection lost from server, dette er noe av de mest irriterende problemene du kan få. Ikke nok med en spill, men dette skjer på alle nettspill, noe som irriterer meg veldig :mad:. :dontgetit:
Dessuten på CSS og DOD:S så løper ikke mennene glatt, de hakker bortover, selv om jeg har 5 i ping og de har f.eks 10 i ping. :dontgetit:
Har Telenor som ISP og Telio ruter, har forwarda alle portene, slått av brannmur og oppdatert PB. Har til og med kjørt Valve sin Network compability test, og har passert alle prøvene. :(
Resultat fra Valves test:
Klikk for å se/fjerne innholdet nedenfor
Results
* UDP Ports: Passed
The following UDP ports were reachable.
UDP Port: 27000 - 27040
* TCP Ports: Passed
The following TCP ports were reachable.
TCP Port: 27020 - 27040
* Background Processes: Failed
The following background processes were found on your system. Please try exiting or uninstalling them, and see if that resolves your issue
o Process: C:\Program Files\Xfire\xfire.exe
XFire is running, which may cause numerous connection problems with Steam and the online games.
Severity: Very High
* Loaded Modules: Passed
There were no loaded modules found that conflict with Steam or the games.
* Services: Passed
There were no services found that conflict with Steam or the games.
* Layered Service Providers: Passed
There were no LSPs found that should conflict with Steam or the games.
Possible Suggestions
If you continue to have problems updating Steam, please exit from Steam, and then delete the following files from your Steam directory.
C:\Program Files\Steam\Steam.dll
C:\Program Files\Steam\SteamUI.dll
C:\Program Files\Steam\ClientRegistry.Blob
If you continue to have problems finding any servers, please exit from Steam, and then delete the following files from your Steam\config directory.
C:\Program Files\Steam\config\serverbrowser.vdf
C:\Program Files\Steam\config\masterservers.vdf
* Basic Information
[+] Day of Defeat: Source
o AutoConfigVersion - 1
o ScreenWidth - 1280
o ScreenHeight - 1024
o ScreenWindowed - 0
o ScreenMSAA - 2
o ScreenMSAAQuality - 0
o ScreenMonitorGamma - 2.2
o mat_forceaniso - 2
o mat_picmip - 1
o mat_trilinear - 0
o mat_vsync - 0
o mat_forcehardwaresync - 1
o mat_parallaxmap - 0
o mat_reducefillrate - 0
o r_shadowrendertotexture - 1
o r_rootlod - 1
o r_waterforceexpensive - 0
o r_waterforcereflectentities - 0
o mat_antialias - 2
o mat_aaquality - 0
o mat_specular - 1
o mat_bumpmap - 1
o mat_hdr_level - 0
o mat_colorcorrection - 1
o VendorID - 4098
o DeviceID - 19018
o DXLevel_V1 - 90
o User Token 2 -
o User Token 3 -
[+] Half-Life 2: Deathmatch
o No settings could be found for this game. This may be a third-party game, or the game has not been launched
[+] Half-Life 2
[+] Counter-Strike: Source
Og ja, jeg har prøvd å slå av Xfire!
Fra å lukke og dra ut ledningene til modemet til å forwardet gir det INGEN resultat :no::no::no:.
Kan noen hjelpe meg ut av dette :hrm:
Resultat fra TweakTest (ser ut til at linjen er god :whistle:)
Endret av specnaz91
HERREGUD! Tror jeg fant problemet men ikke svaret, internettet kobler seg ut hver halv time i 1 sek, kan være at den mister packets. Noen som vet hvordan jeg skal fixe detr?
