Upcoming Test Patch
Gjest Slettet-t9DveYkZ
Såvidt jeg forstår på PcT så har de endret så man nå kun kan kopiere sine egne characters over på test realms, og ikke lage pregenererte level 60-characters der.
Har Blizzard planer om å åpne test realm igjen? Noen som isåfall har patches notes for den kommende patchen?
7775417[/snapback]
http://www.wow-europe.com/en/info/underdev/testrealm.html
Hunters
"Silencing Shot" now does only 50% of weapon damage instead of 75%.
The base damage for "Arcane Shot" has been reduced by about 9% and the bonus damage from ranged attack power reduced from 20% to 15%.
The bonus damage for "Barrage" is now 4/8/12% for ranks 1/2/3.
The bonus damage for "Improved Barrage" is now 4/8/12% for ranks 1/2/3.
Mages
Each rank of "Improved Fireball" now reduces your spell damage coefficient by 2%.
Each rank of "Improved Frostbolt" now reduces your spell damage coefficient by 2%.
"Counterspell" no longer triggers the global cooldown.
"Mana Shield" now absorbs magical damage as well as physical damage.
Priests
The bonus coefficient for "Shadow Word: Pain" has been reduced by about 9%. This should result in about 5% less damage done by "Shadow Word: Pain" for the typical priest.
Bug Fixes
The "Frozen Shadoweave Boots" will now properly increase shadow damage.
Players will no longer lose control of their character if they try to talk to an NPC while mobs are aggro on them.
The /equip command will now work on pieces of gear that are not in your primary bag.
Fixed an issue that was causing some players to disconnect in Hellfire Citadel:Blood Furnace.
The "Corruptor" 4 piece set bonus will now be properly applied.
The Legion Fel Cannons at Forge Camp Anger in Blades Edge will now properly spawn above ground.
The Arena queue tooltip will now show the arena that the player is queued for.
Fixed an error that was causing players to disconnect if they tried to socket a gem that had been gift wrapped.
Fixed an error that was causing players to disconnect forming a party with other members in the same area.
Pet icons will now properly update in the Stables window.
Improved the robustness of the pet action bar display. It is now less likely to be accidentally blocked by addons.
Players will no longer hear the gong sound repeated after initially joining a queue for the battlegrounds.
Having a group invite declined while queued via "Looking for More" will no longer remove you from the queue.
Nethershards will no longer cost honor to purchase but will cost gold instead.
Players will no longer be given access to both quest lines following the Declaration of Allegiance to the Scryers or Aldor in Shattrath City.
Tok meg evigheter å finne det ut og ^^ :p (Fant det ut i starten av EU FB etter å ha spilt i flere måneder i US beta lol.. :p)
Hva er global cooldown?
7775586[/snapback]
Det dritet som kommer på alle spells når du bruker en.
7775672[/snapback]
Cooldown vet jeg hva er, men hvorfor Global cooldown? Finnes det andre typer cooldown el no?
7775586[/snapback]
Vanligvis når du bruker en ability blir det 1sec global cooldown på alle spells, og du må vente 1sec mellom hver ability du vil bruke.
Edit: 1sec, eller 1.4sec, whatever :wee:
Endret av Pug
La oss ta et eksempel:
Prescence of Mind (Mage ability) har 3 minutter cooldown. Det er en cooldown.
Global Cooldown er en cooldown som kommer på alle abilities på 1.4 sekunder. Det betyr at når du bruker en ability (uavhengig av casting time) vil du få en cooldown på -alle- abilities i 1.4 sekunder. Det for å balansere instantspells.
