Cursio Skrevet 6. juni 2005 Skrevet 6. juni 2005 I Liero Xtreme Kan du spille på Lan! I tillegg er det mange interessante endringer: Features: * Higher resolution Liero Xtreme uses 640x480, but the level and other main game graphics are stretched to give the classic 320x200 feel to the game. The higher resolution allows for a better user interface for the main menu, game setup,etc screens * Networking Liero lacked any networking, so Liero Xtreme provides strong and stable networking abilities over a LAN or the internet. With Liero Xtreme you can compete online, as well as a nice option to allow the AI opponents into netplay. * Integrated Map Editor The original Liero had a map editor that was a seperate program. Liero Xtreme has a built-in map editor that allows the players to create the map before they play, or preview the map that they are about to do battle on. The map editor is a good choice for anyone getting familiar with Liero Xtreme map making. Ofcoarse you can design your own maps from scratch for the more advanced graphics savvy gamers. * Moddability Liero Xtreme is designed to read all the weapon data from a simple script. In fact, all the weapons currently in the game are all from a script. None are hard coded in. This is a must for any Liero Xtreme fan. You can create completely custom made weapons trained to do what you want. Liero Xtreme modding may seem a little overwhelming at first to some people, but it gets simple, and there is tons of help available throughout Liero Xtreme's community. * More AI Liero Xtreme has the ability for you to play the most chaotic games against up to 63 computer AI or real opponents! * GUI Liero Xtreme's graphical user interface is like no other Liero clone. It has great, easy to navigate menus, and if thats not enough,you can customize your own GUI right down to the position of the buttons. But if you get bored from a GUI, you can easily switch to another GUI through the options menu. * Community Liero Xtreme has a huge, strong community supporting it. People dedicated to keeping it alive and making levels, mods etc... The community has many tournaments and clans you can join in and play against other people. You can keep up to date on the game's development and maybe learn a few things. * LX Amp Liero Xtreme now comes with its own built in media player to listen to your music while you play. This is also part of the GUI and can be customized.
