Gjest Slettes-xwByZdFZ Skrevet 17. mars 2005 Skrevet 17. mars 2005 Jeg lurer på å kjøpe et par av Disse viftene... men det eneste som står om lyd, er at den er på 0.8 i lydskalaen. jeg lurer på hva sånn ca. dette tilsvarer i desibel?
Zeph Skrevet 17. mars 2005 Skrevet 17. mars 2005 (endret) Noise Level All measurements are taken using full fan speed. The noise level is measured in Sone (loudness) instead of dB (sound pressure). The loudness depends upon ears response curves and tells you exactly, how bothering a certain noise is. Sone takes the frequency and bandwidth of a sound into account. A doubling of the number of Sones sounds to the human ear like a doubling of the loudness. The comparison of products from different manufacturers is basically impossible, since all manufacturers measure in different ways. Even a rough translation from Sone to dB doesn't help. A 15dB cooler can be louder than a 1 Sone cooler from another manufacturer. Nevertheless with the Sone data you can compare our coolers between each other and get a quite precise idea how annoying the product will be. 1 Sone: nearly inaudible in a computer case 2 Sones: clearly audible 3 Sones and more: disturbing Noise Level The noise level is measured in Sone (loudness) instead of dB (sound intensity). The loudness depends upon ears response curves and tells you exactly, how bothering a certain noise is. Endret 17. mars 2005 av zeph
CaZiO Skrevet 17. mars 2005 Skrevet 17. mars 2005 er usikker, men jeg har den s939 kjøleløsningen som srtic cooling bruker den vifta på, og den er veldig stille... ikke over 15db
