Direct X 9.0 Problemer - Removal tool?
balrog52
Hei!
Jeg var ikke helt sikker på hvor jeg skulle legge denne posten, men jeg får prøve her.
Jeg skal legge inn et nytt spill som krever Direct X 9.0. Jeg har bare 8.0, og når jeg skal oppdatere Direct X tar det ca. 1 sekund, så står det "Fullført".
Når dette var gjort Dro jeg en god gammeldags Kjør -> dxdiag. Der stod det fortsatt Direct X 8.0. En kompis fortalte om et slags removal tool der jeg kunne fjerne de gamle DX filene mine, for så å erstatte dem med enten nyere eller gamle. Jeg googla det, og kom opp med ingenting :\
Lurer på om noen vet om et sant tool, eller om jeg må til å formatere hele skiten :p
dette fant jeg:
How do I uninstall DirectX?
A
DirectX 9.0 is a system component and cannot be uninstalled. If there is a problem with the DirectX installation, it can normally be resolved by shutting down all running applications and reinstalling. As mentioned previously, DirectX 9.0 is fully backward-compatible with titles written for previous versions of DirectX. If you are having other problems after installing DirectX 9.0, these can often be resolved by installing updated drivers for your display card, audio card, or input device.
As with most software, users of Windows ME and Windows XP have the option of creating a "System Restore point" before installing. System Restore points allow you to roll back your operating system to a time before the software was installed. If you feel there are special circumstances which may necessitate removal of DirectX. It is recommended that you create a System Restore point. Windows 98, Windows 98 SE, and Windows 2000 do not support the "System Restore" feature.
Windows Millennium Edition: Microsoft Knowledge Base article 267951
Windows XP: Microsoft Knowledge Base article 310405
:nei:
  • 9 måneder senere...
Tror du kan bruke et program som heter XP lite til å uninstalle windows-komponenter (som Directx). Ikke 100% sikker men, lenge siden jeg var borti det.
Hadde det samme problemet. Svaret var at Driverne til skjermkortet ikke fungerte sammen med directX 9.0. Dette er vanlig at det skjer på flere bærbare pc'er vistnok. Så jeg lastet ned noen nye drivere og alt fungerte helt fint.
Oppdater nye skjermdrivere! Last ned eller kjøp en Komputer for alle cd eller noe sånt med DirectX 9.0c! DirectX kan vel ikke fjernes?? Da skulle i teorien ikke Windows fungere lengre...
