Problemer med komplimering av cs map
** Executing...
** Command: Change Directory
** Parameters: C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike
** Executing...
** Command: Copy File
** Parameters: "C:\Programfiler\Valve Hammer Editor\maps\MEG.map" "C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\MEG.map"
** Executing...
** Command: C:\PROGRA~1\VALVEH~1\tools\hlcsg.exe
** Parameters: "C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\MEG"
hlcsg v2.5.3 rel Custom Build 1.7 (Dec 9 2002)
Zoner's Half-Life Compilation Tools -- Custom Build
Based on code modifications by Sean 'Zoner' Cavanaugh
Based on Valve's version, modified with permission.
Submit detailed bug reports to ([email protected])
----- BEGIN hlcsg -----
Command line: C:\PROGRA~1\VALVEH~1\tools\hlcsg.exe C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\MEG
Entering C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\MEG.map
Current hlcsg Settings
Name | Setting | Default
threads [ 1 ] [ Varies ]
verbose [ off ] [ off ]
log [ on ] [ on ]
developer [ 0 ] [ 0 ]
chart [ off ] [ off ]
estimate [ off ] [ off ]
max texture memory [ 4194304 ] [ 4194304 ]
priority [ Normal ] [ Normal ]
noclip [ off ] [ off ]
null texture stripping[ on ] [ on ]
clipnode economy mode [ on ] [ on ]
onlyents [ off ] [ off ]
wadtextures [ on ] [ on ]
skyclip [ on ] [ on ]
hullfile [ None ] [ None ]
min surface area [ 0.500 ] [ 0.500 ]
brush union threshold [ 0.000 ] [ 0.000 ]
Using mapfile wad configuration
Wadinclude list :
[zhlt.wad]
0 brushes (totalling 0 sides) discarded from clipping hulls
CreateBrush:
(0.00 seconds)
SetModelCenters:
(0.00 seconds)
CSGBrush:
(0.02 seconds)
Including Wadfile: \programfiler\valve hammer editor\tools\zhlt.wad
- Contains 2 used textures, 100.00 percent of map (3 textures in wad)
Texture usage is at 0.00 mb (of 4.00 mb MAX)
0.02 seconds elapsed
----- END hlcsg -----
** Executing...
** Command: C:\PROGRA~1\VALVEH~1\tools\hlbsp.exe
hlbsp v2.5.3 rel Custom Build 1.7 (Dec 9 2002)
----- BEGIN hlbsp -----
Command line: C:\PROGRA~1\VALVEH~1\tools\hlbsp.exe C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\MEG
Current hlbsp Settings
log [ on ] [ on ]
nofill [ off ] [ off ]
null tex. stripping [ on ] [ on ]
notjunc [ off ] [ off ]
subdivide size [ 240 ] [ 240 ] (Min 64) (Max 512)
max node size [ 1024 ] [ 1024 ] (Min 64) (Max 4096)
Warning: === LEAK in hull 0 ===
Entity info_player_start @ (-416, 0, 0)
Error:
A LEAK is a hole in the map, where the inside of it is exposed to the
(unwanted) outside region. The entity listed in the error is just a helpful
indication of where the beginning of the leak pointfile starts, so the
beginning of the line can be quickly found and traced to until reaching the
outside. Unless this entity is accidentally on the outside of the map, it
probably should not be deleted. Some complex rotating objects entities need
their origins outside the map. To deal with these, just enclose the origin
brush with a solid world brush
Leak pointfile generated
** Executing...
** Command: C:\PROGRA~1\VALVEH~1\tools\hlvis.exe
hlvis v2.5.3 rel Custom Build 1.7 (Dec 9 2002)
----- BEGIN hlvis -----
Command line: C:\PROGRA~1\VALVEH~1\tools\hlvis.exe C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\MEG
>> There was a problem compiling the map.
>> Check the file C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\MEG.log for the cause.
----- END hlvis -----
** Executing...
** Command: C:\PROGRA~1\VALVEH~1\tools\hlrad.exe
hlrad v2.5.3 rel Custom Build 1.7 (Dec 9 2002)
----- BEGIN hlrad -----
Command line: C:\PROGRA~1\VALVEH~1\tools\hlrad.exe C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\MEG
----- END hlrad -----
** Executing...
** Command: C:\PROGRA~1\Valve\Steam\STEAMA~1\TRONDV~1\COUNTE~1\hl.exe
** Parameters: +map "MEG"
Hva kan feilen være? Får ikke kjørt mappet
Error:
for å fikse må du tette hullet :)
letteste måten er jo selvsagt å lage en gigantisk boks rundt hele brettet ditt og gjøre den hul, med tynne vegger altså :) gi den gjerne teksturen sky
funka ikke selv om jeg tetta hullet. Det kommer også en feilmelding om:
"hlbsp.exe har et problem og må lukkes. Vi beklager det inntrufne"
Kan det være noe med innstilingene? er ikke helt sikker på om jeg gjorde de riktig
Endret av csboy
Er da noe feil med din maskin vis hlbsp kræsjer.
Men det er en leak i brette ditt, load point fila i hammer, se om du har tetta alle hullene i brette ditt.
Har tetta hullet men funka fortsatt ikke. Vil det si at jeg ikke kan lage maps pga feilmed maskina?
Edit: Prøvde å bare lage en firkant. da fikke jeg denne meldingen:
** Executing...
** Executing...
** Parameters: "C:\Programfiler\Valve Hammer Editor\maps\liten.map" "C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\liten.map"
** Executing...
** Parameters: "C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\liten"
Command line: C:\PROGRA~1\VALVEH~1\tools\hlcsg.exe C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\liten
Entering C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\liten.map
log [ on ] [ on ]
Wadinclude list :
[zhlt.wad]
CreateBrush:
50%... (0.00 seconds)
SetModelCenters:
(0.00 seconds)
CSGBrush:
- Contains 1 used texture, 100.00 percent of map (3 textures in wad)
0.00 seconds elapsed
** Executing...
Command line: C:\PROGRA~1\VALVEH~1\tools\hlbsp.exe C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\liten
log [ on ] [ on ]
Warning: No entities exist in hull 0, no filling performed for this hull
Warning: No entities exist in hull 1, no filling performed for this hull
Warning: No entities exist in hull 2, no filling performed for this hull
Warning: No entities exist in hull 3, no filling performed for this hull
----- END hlbsp -----
** Executing...
Command line: C:\PROGRA~1\VALVEH~1\tools\hlvis.exe C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\liten
Error: Portal file 'C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\liten.prt' does not exist, cannot vis the map
** Executing...
Command line: C:\PROGRA~1\VALVEH~1\tools\hlrad.exe C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\liten
>> Check the file C:\Programfiler\Valve\Steam\SteamApps\trondvatne\counter-strike\cstrike\maps\liten.log for the cause.
** Executing...
** Parameters: +map "liten"
Jeg fikke heller ikke den feilmeldingen om at hlbsp.exe har et problem og må lukkes. Tror det kan være noe med innstillengene for jeg er ikke sikker på om jeg gjorde det riktig
Endret av csboy
Du har ingen entitier i brettet ditt, iallefall ikke der VIS kjører. Plasser ut en info_player_start.
Bruker du texture fra den wad fila er problemet der. Du må bruke texture fra hl.wad eller cstrike.wad fila, og ikke bare fra zhlt.wad (som er beregnet for alt annet enn å dekorere et brett)
Edit: Hel idiotsik skrivefeil (les quoten nedenfor)
Endret av Bear^
Bruker du har texture fra den wad fila er problemet der. Du må bruke texture fra hl.wad eller cstrike.wad fila, og ikke bare fra zhlt.wad (som er beregnet for alt annet enn å dekorere et brett)
Det var feilen ja. Funka nå :thumbup: Men jeg glemte å legge til lys da. hehe
