Popper opp vinduet!
Hva skjer... vindu på vindu popper opp med denne adresse
http://errorpage123456.back.to/ ..
og noen ganger står det
Warning: mysql_connect(): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (61) in /usr/home/wreck3d/buzz.to/redirect/include/vars.php on line 32
Warning: mysql_select_db(): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (61) in /usr/home/wreck3d/buzz.to/redirect/include/vars.php on line 33
Warning: mysql_select_db(): A link to the server could not be established in /usr/home/wreck3d/buzz.to/redirect/include/vars.php on line 33
Warning: mysql_query(): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (61) in /usr/home/wreck3d/buzz.to/redirect/include/vars.php on line 35
Warning: mysql_query(): A link to the server could not be established in /usr/home/wreck3d/buzz.to/redirect/include/vars.php on line 35
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /usr/home/wreck3d/buzz.to/redirect/include/vars.php on line 36
Warning: mysql_query(): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (61) in /usr/home/wreck3d/buzz.to/index.php on line 29
Warning: mysql_query(): A link to the server could not be established in /usr/home/wreck3d/buzz.to/index.php on line 29
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /usr/home/wreck3d/buzz.to/index.php on line 30
Warning: Cannot modify header information - headers already sent by (output started at /usr/home/wreck3d/buzz.to/redirect/include/vars.php:32) in /usr/home/wreck3d/buzz.to/index.php on line 31
Åssen blir jeg kvitt den dritten.
Er noen rare exe filer som går også...
sdads.exe
kalyal.exe
polo.exe
hilfiger.exe
Seriøst, nå klikker det mentalt for meg snart.
Høres ut som du har utøy på maskinen din:
1. Kjør først Housecall for å utelukke virus, ormer osv.
2. Kjør så Ad-aware for å renske ut spyware, dialers osv.
3. Kjør til slutt Spyboot for å se om denne finner noe som de ovenfor ikke fant.
Husk å laste ned nye signaturer før du kjører punkt 2 og 3.
