Tetra mann Skrevet 18. juni 2025 Skrevet 18. juni 2025 Hei, jeg leter etter denne Kobling til Strømforsyning , noen som vet navnet? Jeg må ha Hun til denne hannen.
ps5 Skrevet 18. juni 2025 Skrevet 18. juni 2025 ChatGPT er gratis og sier The cable in the image appears to be a 2-pin JST connector, specifically a JST SM or JST XH type, which is commonly used in low-voltage electronics for DC power connections. Here are a few details: 2-pin connector: Typically used for power (red for positive, black for ground). Latch mechanism: The clip on the side helps it lock into place to avoid accidental disconnection. Applications: Frequently found in LED strips, RC batteries, small electronics, and Arduino-type DIY projects. To be more precise: If the pitch (distance between the pins) is 2.5 mm, it’s likely a JST XH. If it's 2.54 mm (0.1 inch) or more rugged, it might be a Molex KK or similar. If you have calipers or a ruler, measuring the pin spacing can help confirm the exact type. Let me know what it’s connected to, and I can narrow it down further. 1
toralfb Skrevet 19. juni 2025 Skrevet 19. juni 2025 Til en batteripakke? Butikker som selger radiostyrte biler og lignende har gjerne slike kontakter?
sedsberg Skrevet 19. juni 2025 Skrevet 19. juni 2025 (endret) Quote The image displays a 2-pin Molex "Mini-Fit Jr." nylon line plug, a type of electrical connector. While Molex is a prominent manufacturer of such connectors, similar generic versions are also available. Den stemmer bedre. https://www.molex.com/en-us/products/part-detail/469920220 Endret 19. juni 2025 av sedsberg 1
