Problemer med å brenne ISO fil, får feilmelding !
Jeg har en "PLEXTOR CD-R PX-W2410A" cd brenner, jeg prøver å brenne boot.iso filen som følger med Linux Suse 9.0. HAr lastet ned filen flere ganger fra fra forskjellige FTP servere (brukt "bin" nedlastning) og har prøvd å brenne CD'en med boot.iso filen minst 4 ganger, men får følgende feilmelding hver gang:
File ThreadedTransferInterface.cpp, Line 994
Write error
21 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 994
Could not perform Fixation
Nå gidder jeg ikke å bruke flere Cd'er, kan noen hjelpe meg med denne feilen?
Her er hele log filen hvis dette kan være til hjelp:
My PC
1502-4340-1150-0511-6200-0998*
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 29.01.2003 21:37:36
Nero Version: 5.5.10.54
Recorder: <PLEXTOR CD-R PX-W2410A>Version: 1.02 - HA 0 TA 1 - 5.5.10.54
Adapter driver: <atapi> HA 0
Drive buffer : 4096kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <ATAPI DVD-ROM 16X> Version: 625A - HA 1 TA 0 - 5.5.10.54
Adapter driver: <atapi> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y080P0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PLEXTOR CD-R PX-W2410A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : ATAPI DVD-ROM 16X atapi Port 1 ID 0 DMA: On
AutoRun : 0
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 273MB (279872kB)
Memory in use : 46 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: Off
29.11.2003
CD Image
14:33:41 #1 Phase 72 File dlgbrnst.cpp, Line 1655
BURN-Proof activated
14:33:41 #2 Text 0 File Reader.cpp, Line 115
Reader running
14:33:41 #3 Text 0 File Writer.cpp, Line 125
Writer PLEXTOR CD-R PX-W2410A running
14:33:41 #4 Text 0 File Burncd.cpp, Line 3769
Turn on Track-At-Once, using CD-R/RW media
14:33:41 #5 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (original item values)
0: TRM_DATA_MODE1 (CD-ROM Mode1, Joliet)
2 indices, index0 (150) not provided
original CD pos #0 + 11238 (11238) = #11238/2:29.63
relocatable, CD pos for caching/writing not required/not required, patch infos
14:33:42 #6 Text 0 File DlgWaitCD.cpp, Line 229
Last possible write address on media: 359845 (79:59.70)
Last address to be written: 22625 ( 5:03.50)
14:33:42 #7 Text 0 File DlgWaitCD.cpp, Line 234
Write in overburning mode: FALSE
14:33:42 #8 Text 0 File DlgWaitCD.cpp, Line 1703
Recorder: PLEXTOR CD-R PX-W2410A;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
14:33:44 #9 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder PLEXTOR CD-R PX-W2410A for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD not fixated
Tracks 2 to 2:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 23322624
14:33:44 #10 Text 0 File ThreadedTransferInterface.cpp, Line 852
Removed 2 run-out blocks from end of track 2.
14:33:44 #11 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 11236 blocks [PLEXTOR CD-R PX-W2410A]
14:33:44 #12 Phase 24 File dlgbrnst.cpp, Line 1655
Caching of files started
14:33:44 #13 Phase 25 File dlgbrnst.cpp, Line 1655
Caching of files completed
14:33:44 #14 Phase 36 File dlgbrnst.cpp, Line 1655
Burn process started at 24x (3 600 KB/s)
14:33:44 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1978
Verifying CD position of item 0 (relocatable, no CD pos, patch infos, orig at #0): write at #11388
14:33:44 #16 Text 0 File Mmc.cpp, Line 19092
Set BUFE: BURN-Proof -> ON
14:34:10 #17 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
14:34:13 #18 Text 0 File Mmc.cpp, Line 14085
<PLEXTOR CD-R PX-W2410A> start Close Session
14:35:00 #19 SCSI -1135 File Cdrdrv.cpp, Line 1241
SCSI Exec, HA 0, TA 1, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0xFF 0xFF 0xD8 0x50 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
14:35:00 #20 MMC -1135 File ThreadedTransferInterface.cpp, Line 994
Write error
14:35:00 #21 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 994
14:35:00 #22 Text 0 File Mmc.cpp, Line 14085
14:35:58 #23 SCSI -1135 File Cdrdrv.cpp, Line 1241
Sense Code: 0x0C
Sense Qual: 0x00
Sense Data: 0xF0 0x00 0x03 0xFF 0xFF 0xD8 0x9A 0x0A
14:35:58 #24 MMC -1135 File ThreadedTransferInterface.cpp, Line 994
Write error
14:35:58 #25 TRANSFER -19 File ThreadedTransferInterface.cpp, Line 994
14:35:58 #26 Phase 38 File dlgbrnst.cpp, Line 1655
Burn process failed at 24x (3 600 KB/s)
14:35:58 #27 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\NeroCD2k.sys': Ver=1.0.0.9, size=44227 bytes, created 16.04.2001 11:54:26
File 'Drivers\CDR4_2K.SYS': Ver=5.3.2.31, size=58000 bytes, created 01.07.2003 23:36:41
File 'Drivers\CDRALW2K.SYS': Ver=5.3.2.31, size=23420 bytes, created 01.07.2003 23:36:41
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29.08.2002 00:27:50 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Endret av tante_olga
Hm. Jeg vet ikke hva som er galt, men det høres grisete ut. Har du sett om iso-en er i orden? Typisk mountet med Daemon eller åpnet med WinRAR/WinISO/ISOBuster?
