Athelas Skrevet 22. juni 2008 Skrevet 22. juni 2008 Er det noen som kan sette opp en enkel step-by-step guide til å installere addons i AoC? Har spilt WoW før, og synes det var ekstremt mye enklere der. Finnes det et verktøy som gjør dette bedre i AoC?
Crowly Skrevet 22. juni 2008 Skrevet 22. juni 2008 (endret) Hva er det som er så vanskelig ? Av hva jeg husker fra når jeg spilte WoW, så måtte man kopiere addons'ene inn i en gitt mappe, det er akkurat det samme i AoC. Hvis du har standard installasjons path, så skal du kopiere filene inn i Customized mappa som ligger under: ... \Funcom\Age of Conan\cd_image\Gui , noen addons legger også noen filer i Default mappa. Dette er readme.txt fila som ligger i Customized mappa This folder is for customized GUI XML files. If you try to modify a file in the "cd_image/Gui/Default/" folder or one of its children, it will automatically be reverted by the patcher. If you want to customize any of the GUI files, you should first copy it to the "cd_image/Gui/Customized/" folder. If the file is located in a child folder of "cd_image/Gui/Default/" the same folder structure must be made in "cd_image/Gui/Customized/". The game will first check the "cd_image/Gui/Customized/" folder to see if the file is there. If it is and the revision number is the same as the version in "cd_image/Gui/Default/", the customized version will be used. Any time the official version is updated the revision number will be increased. If the customized version has a different revision number than the official file, a warning dialog will be displayed ingame and the official file will be used. If this happens, you must update the revision number in the customized file but it is recommended you copy over the entire official file and reapply your customizations. This is to prevent you from losing any new functionality that might have been added to the file. The revision number can also be used to temporarily prevent the game from loading a customized file. If it is set to '0', the official file will always be loaded and no warning dialog will pop up. All GUI XML files start with a XML comment containing the revision number, where XXXXX is the revision number: <!-- $Change: XXXXX $ (must be within the first 200 characters of the file) --> De fleste addons kommer også med en readme fil som forteller deg hva og hvor du skal kopiere de forskjellige filene. De jeg har vært borti kommer med ferdig mappe struktur for Default og Customized (alt etter hva de benytter), så det er bare å kopiere de mappene inn i Gui mappa. Edit: Når Funcom patcher, så må alle addons oppdaters, da kan denne: AoC Custom UI Patcher være kjekk å bruke, hvis det ikke er oppdaterte utgaver av addons'ene for siste versjon. Får man problemer med en addons så er det egentlig bare å slette de fra Customized mappa, vet man ikke nøyaktig hvilke filer man skal slette, så bare slett alt i Customized mappa, og kopier inn de addons'ene du vil ha på nytt. Endret 22. juni 2008 av Crowly
LarZen Skrevet 22. juni 2008 Skrevet 22. juni 2008 Huff...dem har støtte for addons i AoC også altså? Viste ikke dette jeg... Skal ikke installere en jævla addon her ivertfall...
Walts Skrevet 22. juni 2008 Skrevet 22. juni 2008 er vel ikke helt støtte for addons i aoc, men støtte for custom UI, man kan altså forandre på ting, men man kan ikke legge til nye ting som f.eks da i wow decursive, grid etc...
LarZen Skrevet 22. juni 2008 Skrevet 22. juni 2008 er vel ikke helt støtte for addons i aoc, men støtte for custom UI, man kan altså forandre på ting, men man kan ikke legge til nye ting som f.eks da i wow decursive, grid etc... Slik å forstå ja..husker bare hvordan det var i WoW til tider. På det værste så måtte raidet oppgradere endel addons opp til flere ganger da det kom hele tiden nye versjoner og alle måtte ha den samme.
Nietsroht Skrevet 22. juni 2008 Skrevet 22. juni 2008 (endret) er egentlig ganske greit. bare følge beskrivelsen over. Men hva når man skal ha flere? eks en for group window og en for map etc.... har slitt litt med det egentlig. Noen som har tips? Endret 22. juni 2008 av Nietsroht
Licht Skrevet 22. juni 2008 Skrevet 22. juni 2008 (endret) er egentlig ganske greit. bare følge beskrivelsen over. Men hva når man skal ha flere? eks en for group window og en for map etc.... har slitt litt med det egentlig. Noen som har tips? Skal vel gå an med mindre de forskjellige addonene forandrer på samme fil. I så fall må du til med saks og lim (i digital forstand)l Huff...dem har støtte for addons i AoC også altså? Ja, og godt er det. Skulle nesten tro MMO-departementet krevde at nye spill ble levert med elendige UI. Endret 22. juni 2008 av Zealuu
