Akidon Skrevet 19. mars 2008 Skrevet 19. mars 2008 (endret) Spiller Enemy Territory: Quake wars. Etter å ha vert inne på serveren i min blir jeg kicket fordi "Pnkbstr failed to intialize". Har prøvd å instalere manuelt og kjørte en test. Fikk opp dette: Starting PunkBuster Service Tests (v0.986) (03/19/08 15:59:15)Checking OS Windows XP (build 2600, Service Pack 2) 32-bit Checking PnkBstrA service status RUNNING Checking PnkBstrA Version OK (1029) Extracting "PnkBstrB.exe" to: "C:\Documents and Settings\Akidon\Programdata\PnkBstrB.exe" OK Checking firewall settings OFF Is PnkBstrA explicitly allowed? C:\WINDOWS\system32\PnkBstrA.exe YES Is PnkBstrB explicitly allowed? C:\WINDOWS\system32\PnkBstrB.exe YES Checking if PnkBstrB is running NOT RUNNING Getting port for PnkBstrA OK (44301) Opening socket for packet send OK Sending version packet to PnkBstrA SENT Receiving version from PnkBstrA OK Received 6 bytes from 127.0.0.1:44301 Response = 7031 (ms) Version = v1029 Getting PnkBstrB install instance OK Sending start packet to PnkBstrA SENT Waiting for packet from PnkBstrA OK Received 3 bytes from 127.0.0.1:44301 Response = 11031 (ms) PnkBstrB DID NOT start. Load FAILED. PnkBstrA.log: 8 15:55:17] ERROR: Ignoring load request coming within a few seconds of prior load [03.19.2008 15:55:32] ERROR: Failed to load PnkBstrB (error:1450) [03.19.2008 15:55:47] ERROR: Failed to load PnkBstrB (error:1450) [03.19.2008 15:56:02] ERROR: Failed to load PnkBstrB (error:1450) [03.19.2008 15:56:07] ERROR: Failed to load PnkBstrB (error:1450) [03.19.2008 15:59:23] ERROR: Failed to load PnkBstrB (error:1450) Watching for PnkBstrB instance change (2) Noen som vet hvordan jeg kan fikse dette? Endret 19. mars 2008 av Akidon
