Problemer med azureus/java
Hei. Da jeg forsøker å åpne azureus får jeg denne meldinga:
martin@martin-laptop:~$ azureus
changeLocale: *Default Language* != English (Norway). Searching without country..
changeLocale: Searching for language English in *any* country..
changeLocale: no message properties for Locale 'English (Norway)' (en_NO), using 'English (default)'
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0xb045bd02, pid=24875, tid=3084912304
# Java VM: Java HotSpot Client VM (1.5.0_08-b03 mixed mode, sharing)
# Problematic frame:
# C [libglibjni-0.4.so+0x8d02]
# An error report file with more information is saved as hs_err_pid24875.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
Aborted (core dumped)
Noen som vet hva som er feil og kan hjelpe meg?
Hadde jeg funnet denne så, har forsøkt å søke etter den, men finner den ikke. Virka derimot da jeg fjerna azureus, som var lagt inn med atp, og la inn ved å hente den fra sourceforge.
  • 1 måned senere...
Eller denne funket for meg
If you don’t like using µTorrent with Wine for your torrents, chances are you’re on Azureus. However, the package from Ubuntu’s repos has issues: it won’t show up in or minimize to the system tray and warning pop-ups won’t go away. It is, not surprisingly, a Java issue. This is what you do.
1. Install azureus from the Ubuntu repos.
2. Download the appropriate version from the official Azureus site: http://azureus.sourceforge.net/download.php.
3. Unpack Azureus2.jar from the downloaded archive and copy it over the existing one from the Ubuntu installation: sudo cp /home/user/Desktop/Azureus2.jar /usr/share/java/Azureus2.jar.
You can also install the whole thing from the Azureus website, but you won’t have a .desktop file to go along with it (I dislike creating them) and will have to remove manually, since it isn’t a package.
Har gjort dette og nå fungerer alt.
