Ny gothic 3 patch (1.08)
som sagt er det nå kommet en ny patch til gothic 3 :love:
link
Dette gjør den (har puttet den i spoiler for å spare plass)
Klikk for å se/fjerne innholdet nedenfor
Build 1.08
- Several crash bugs fixed
- Performance increased
- Combat AI for several monsters improved/simplified (e.g. boar)
- Lots of AI Fixes ( Murderer Reaction from party member fixed, AI comments improved)
- Sleeping NPC's AI reactions improved
- Camera Control: Inverting the X-axis is now saved
- Lensflare/Sun doesn't shine through mountains and buildings anymore
- Rhobar and Zuben are dead after defeating them
- Revolution mechanics improved
- Lester does now talk even when not sitting at the campfire
- Epilogue fixed
- "No mission success after 2 times "not enough gold" fixed
- Vak and Gonzales are now still there after a revolution
- There are now more weapons at traders and in chests
- Annoying NPCs from Faring arena removed
- Story and Missions in Al shedim improved. (Lester,Saturas,Wutras,etc...)
- Snorre's ancestor stone fixed
- All problems of Hogar and the southern Orcs fixed
- Ronar Trading fixed
- Less monsters/Orcs in Nordmar
- Vibald is now carrying explosive arrows
- Bogir dialog fixed
- Osmund dialog fixed
- Crossbow handling improved"
Endret av cannavaro
Najs! Tidligere enn hva som var ventet :)
Patchen virker med alle versjonene ja. Gamle savegames kan fremdeles brukes, men:
NB! Unequip alle items, SAVE, QUIT, og så kan du installere patchen!
Endret av Frosten
7163780[/snapback]
Why?
EDIT: Altså, hvorfor må man det?
Endret av E-wok
Why?
7163858[/snapback]
Det er beskjeden fra Jowood's eget forum da de postet patchen.
Kilde: Offisiell tråd om patchen
Better safe than sorry, no? ;)
Og cracken vil nok heller ikke virke lengre hvis noen trodde det.
Endret av Frosten
0. POSSIBLE EXPLOIT
To avoid using the patches (same for 1.07) as an exploit:
- unequip all items
- save game
- apply patch
- load game
Otherwise equipment bonuses will be counted doubly after reequipping.
dette er grunnen til at man skal gjøre det som frosten sier
link
7163897[/snapback]
Rekna ikkje med det, men det kjem vonleg ein ny NOCD-patch om ei stund.
Skulle ønske Piranha berre kunne innsjå at kopibeskyttelsen deira sug, og fjerne han sjølv.
Kay
Får faktisk starta opp spillet med nocn crack, men får opp en melding under loading om no script greier (husker ikke hva det stod), men jeg valgte og ignorere den og kom inn i spillet, men der stod bare folka å så på hverandre.
Eneste jeg fikk gjort var å gå rundt;/
hehe
Sjølvsagt funkar det ikkje med NOCD-patch for forrige versjon, slikt er det ikkje nokon vits i å prøve seg på ein gong :). NOCD-patchen blir jo installert ved å erstatte tre av dei viktigaste filene i Gothic3-katalogen, som sannsynlegvis alle har blitt forandra i siste offisielle patch. Dersom du mot formodning hadde fått det til å køyre, ville du sannsynlegvis mista dei fleste av forbetringane som hadde blitt gjort.
Kay
Kay
7164292[/snapback]
Men det starta da=P
Hadde ikke trodd det ville starta i det heletatt=)
Heh, hadde ingen problemer med Gothic 3 før patchen. Nå når jeg har lastet ned patchen og innstallert den, så ser jeg haugevis av store røde firkanter som dukker opp i horisonten samt at flere NPC'er har bare plutselig forsvunnet... ARGH! Skulle aldri ha patchet Gothic...
Endret av xm8
HA! Juger i changeloggen sin gjør de også.
Endret av EvilHomer
En ting jeg lurer på.. Blir det bedre ytelse av å bruke NOCD istedenfor å ha DVDen inni? Har hørt noe sånt ettersom sikkerhetsprogrammet sjekker hele tiden sånn at det tar systemressurser eller noe sånt.
7165514[/snapback]
For meg halverte det nesten lastetidene.
Kay
hos meg har ytelsen økt så vidt
har ikke hatt noen store problemer eller bug enda :)
spillet har vel låst seg ett par ganger siden jeg innstalerte det også er det jo den der sol-greia :p
har bare hatt minimalt med hakking og enda mindre etter patchen :)
