Hva er en dll fil?
Kan lese litt om det her:
http://en.wikipedia.org/wiki/DLL
Dynamic-link library (DLL), also referred to as dynamic link library (without the hyphen), is Microsoft's implementation of the shared library concept in the Microsoft Windows operating systems. These libraries usually have the file extension DLL, OCX (for libraries containing ActiveX controls), or DRV (for legacy system drivers).
Du kan ikke åpne dll filer på vanlig måte. Dersom du programmerer, kan du benytte deg at dll filer for å enkelt legge til funksjonalitet.
