akarno Skrevet 28. august 2005 Skrevet 28. august 2005 (endret) Hei! meg og en kompis hadde det litt gøy idag! Dette er tatt fra guild forumet mitt; postet av meg -------------------------------------------------------------- After I got to lvl 40 (again) and got the mount. I decided to try to get "out of bounds" a bit... Here's the result (Woking joined the second try Thanks woking, it was awesome ) Here's the top, where I first saw "the end" http://img367.imageshack.us/img367/9593/wo...051732562rj.jpg I ran down, seing an edge at the end, thinking "its probably an invisible wall there!" http://img367.imageshack.us/img367/9836/wo...051733365ha.jpg Yeh! kinda far down! http://img367.imageshack.us/img367/3231/wo...051734107xf.jpg Yeah.. no invisible wall there for sure! http://img367.imageshack.us/img367/7352/wo...051734445lx.jpg You can probably imagine what happened next So, as I forgot to soulstone, and told woking about it, we decided to go together. I fetched a soulshard and we started climbing (the climbing took about 30 min to do) Some of the "climbing" http://img265.imageshack.us/img265/9006/wo...051826233zl.jpg And as we got to the edge, I did a soulstone on him, and he being a druid he could resurrect me when he had used the soulstone down there... Fanceeey! http://img265.imageshack.us/img265/8140/wo...051829070se.jpg Off we go! http://img150.imageshack.us/img150/4769/wo...051829309sg.jpg http://img150.imageshack.us/img150/8008/wo...051829372ia.jpg After resurrecting and stuff (which if forgot to take screenshot of), we ran around for a bit.. the endless plains... Took a look up where we'd jumped off http://img150.imageshack.us/img150/5701/wo...051834539zm.jpg We ran around http://img150.imageshack.us/img150/3021/wo...051835431wq.jpg In the end we got to the edge of the mountain... There was sea down there.. we decided to jump as we had to go quite soon... http://img150.imageshack.us/img150/5789/wo...051840073xw.jpg As you can see; not too smart... When we was done, we released our spirits.. And ended up in desolace (wtf, thats FAR from where we were!!!) http://img190.imageshack.us/img190/8444/wo...051841476ug.jpg And thats how the Adventures of Woking and Akarno ends ----------- Sånn, bare links nå, og litt mer oversiktlig Endret 28. august 2005 av Icluz
anon12234 Skrevet 28. august 2005 Skrevet 28. august 2005 fare for å bli bannet hvis du gjør det der......
OscarWoHA Skrevet 28. august 2005 Skrevet 28. august 2005 fare for å bli bannet hvis du gjør det der...... Man blir ikke bannet nei?
akarno Skrevet 28. august 2005 Forfatter Skrevet 28. august 2005 (endret) Hæ? Seriøst? Jeg bare prøvde meg fram og utforsket litt, fant en veg å komme opp! Kan vel ikke bli bannet av det? Hadde jo vert helt teit! Det er vel bare å forklare det for Blizzard! Fant en veg som ikke var helt ment til å gå opp liksom, hvordan skulle jeg vite det? Skal jeg bare slette alle bildet etc fra nettet for å være sikkert? Endret 28. august 2005 av Icluz
Fnix Skrevet 28. august 2005 Skrevet 28. august 2005 Du blir ikke bannet nei men var store bilder gitt..
zbegra Skrevet 28. august 2005 Skrevet 28. august 2005 Man blir ikke bannet, eneste som skjer er at GM framtvinger Heartstone.
dimdal Skrevet 28. august 2005 Skrevet 28. august 2005 Det er alltid en eller annen liten viktigper som skal ødelegge, samme skjedde i min tråd med bilder fra Hyjal.
Keylar Skrevet 28. august 2005 Skrevet 28. august 2005 Fin historie men thumb's eller links bare please
akarno Skrevet 28. august 2005 Forfatter Skrevet 28. august 2005 Fin historie men thumb's eller links bare please Fikset, og gjort mer oversiktlig
str00tz Skrevet 29. august 2005 Skrevet 29. august 2005 hvorfor er det ALLTID noe som skal si "BANN!!!1111oneoneone..." ?
