Hurtigtaster i MediaMonkey *LØST*
Får man hurtigtaster til MediaMonkey??
Sånn som det er i winamp...
F.eks Ctrl+Alt+Page up for å bytte sang
Endret av Hrisebro
Ja.
Keyboard & Mouse Shortcuts
MediaMonkey can help you work more efficiently with your music Library with the following shortcuts.
Multimedia Keyboard Shortcuts
The following buttons on multimedia keyboards can be used to control MediaMonkey:
Play / Pause / Stop
Previous Track / Next Track
Volume Up / Volume Down
Search
Previous View / Next View / Refresh
Standard Keyboard Shortcuts
The following shortcuts can be accessed via a standard keyboard:
Play / Pause <Ctrl><p>
Previous Track (back) <Ctrl><b>
Next Track (forward) <Ctrl><n>
Back 5 Seconds <Shift><Ctrl><b>
Forward 5 Seconds <Shift><Ctrl><n>
Play (selected Tracks) Now (can be changed by modifying 'Double-click action') <Enter>
Play (selected Track) Now - Alternate
(see Player Configuration) <Alt><Enter>
Play (selected Tracks) After Others <Ctrl><Enter>
Play (selected Tracks) Next <Shift><Ctrl><Enter>
Edit Properties of selected Tracks <Shift><Enter>
Advance Track in Property Editor <Alt><Right arrow>
Previous Track in Property Editor <Alt><Left arrow>
Delete Selected Tracks (recycle bin) <Delete>
Permanently Delete Selected Tracks <Shift><Delete>
Select First Track <Home>
Selecet Last Track <End>
Select All Tracks <Ctrl><a>
Search <Ctrl><f> or <F3>
Auto-Tag from Amazon <Ctrl>-<l>
Auto-Tag from filename <Ctrl>-<t>
Auto-Organize <Ctrl>-<r>
Synchronize Tags <Ctrl>-<s>
Rip Audio CD <Shift><Ctrl><r>
Convert Audio Format <Shift><Ctrl><c>
Burn Audio CD <Shift><Ctrl><a>
Save Preview <Shift><Ctrl><p>
Analyze Volume <Shift><Ctrl><v>
Previous node back <Alt><Left>
Previous node forward <Alt><Right>
Resize Columns <Ctrl><Numpad+>
Refresh View <F5>
Refresh play order to match sort order (in Playlist nodes) <Alt><F5> or <Ctrl><Alt><F5>
Show Now Playing node <F6>
Show Library node (collapsed) <F7> or <Alt><Home>
Show Artists node <F8>
Show Albums node <F9>
Show Genre node <F10>
Show Year node <F11>
View Album Browser (toggle) <Ctrl><Alt><a>
View Properties editor (toggle) <Ctrl><Alt><p>
View Player (toggle) <Ctrl><Alt><l>
View Now Playing dialog (toggle) <Ctrl><Alt><n>
View Visualization (toggle) <Ctrl><Alt><v>
View Equalizer (toggle) <Ctrl><Alt><e>
Numeric Keypad Shortcuts
You can also access the player commands using the numeric keypad. This is useful if you don't have a multimedia keyboard, and don't want to have to press multiple keys to control the player. By default, these shortcuts are active when the numeric keypad is disabled (i.e. when Num Lock is off -- see Player Configuration for details) :
Play (selected Tracks) Now (can be changed by modifying 'Double-click action') <Enter> (numeric pad)
Play/Pause <0> (numeric pad)
Stop <.> (numeric pad)
Previous Track <7> (numeric pad)
Next Track <9> (numeric pad)
Back 5 seconds <1> (numeric pad)
Forward 5 seconds <3> (numeric pad)
Volume Up <8> (numeric pad)
Volume Down <2> (numeric pad)
Balance Left <4> (numeric pad)
Balance Right <6> (numeric pad)
Balance Center <5> (numeric pad)
Show 'Now Playing' <+> (numeric pad)
Mouse Gestures
When the application is minimized, you can still control the player by performing 'Mouse gestures' over the system tray icon:
Restore application Double-click icon
Play / Pause Click icon
Previous Track Drag left on icon
Next Track Drag right on icon
Volume Up Drag up on icon
Volume Down Drag down on icon
de funker ikke i spill :no:
Jeg må ha noe som funker i spill, og jeg skal IKKE bytte mediaplayer.!!
Endret av Hrisebro
Jeg testet å bruke mediatastene til å styre musikken mens jeg spillte San Andreas, og det fungerte fint. Ikke akkurat en løsning på ditt problem, men da vet du i alle fall at det vil fungere når du kjøper et nytt tastatur. :)
