Rogue talent build- Er denne god?
Assassination Talents (21 points)
Malice - 5/5 points
Increases your critical strike chance by 5%.
Improved Eviscerate - 3/3 points
Increases the damage done by your Eviscerate ability by 15%.
Ruthlessness - 3/3 points
Gives your finishing moves a 60% chance to add a combo point to your target.
Improved Slice and Dice - 3/3 points
Increases the duration of your Slice and Dice ability by 45%.
Relentless Strikes - 1/1 point
Your finishing moves have a 20% chance per combo point to restore 25 energy.
Vile Poisons - 5/5 points
Increases the damage dealt by your poisons by 15%.
Cold Blood - 1/1 point
When activated, increases the critical strike chance of your next Sinister Strike, Backstab, Ambush, or Eviscerate by 100%.
Combat Talents (28 points)
Improved Gouge - 3/3 points
Increases the effect duration of your Gouge ability by 1.5 seconds.
Improved Sinister Strike - 2/2 points
Reduces the Energy cost of your Sinister Strike ability by 5 Energy.
Precision - 5/5 points
Increases your chance to hit with melee weapons by 5%.
Deflection - 5/5 points
Increases your Parry chance by 5%.
Riposte - 1/1 point
A strike that becomes active after parrying an opponent's attack. This attack deals 150% weapon damage and disarms the target for 6 seconds.
Dual Wield Specialization - 5/5 points
Increases the damage done by your offhand weapon by 50%.
Dagger Specialization - 5/5 points
Increases your chance to get a critical strike with Daggers by 5%.
Improved Kick - 2/2 points
Gives your Kick ability a 100% chance to silence the target for 2 seconds.
Subtlety Talents (2 points)
Master of Deception - 2/5 points
Reduces the chance enemies have to detect you while in Stealth mode. More effective than Master of Deception (Rank 1)
Kjører dual dagger ettersom jeg har fått 2 veldig gode nå..
Problemet var at jeg ville ha både AR og CB.. Men da man jo være lvl 61 :nei:
Forslag til build? Dette er ganske "hybrid" vet jeg men jeg ville ikke kjøre så mye combat / sublety (som jeg gjorde før)
hmm er ikke helt enig i det oppsettet der , du kjører dual daggers, og ser at du ikke har ambush eller backstab der i det hele tatt , med det oppsettet ser jeg ingen grund til å kjøre lav dmg daggers, jeg skal sette opp et tips til deg angående dagger spec:
Malice - 5/5 points
Relentless Strikes - 1/1 points
Murder - 2/2 points
Increases your chance to hit while using your Sap, Ambush, Garrote, or Cheap Shot abilities by 5%.
Lethality - 5/5 points
Increases the critical strike damage bonus of your Sinister Strike, Gouge, Backstab, Ghostly Strike, or Hemorrhage abilities by 30%.
Improved Expose Armor - 1/3 points
Increases the armor reduced by your Expose Armor ability by 15%.
Cold Blood - 1/1 points
Combat Talents (8 points)
Improved Backstab - 3/3 points
Increases the critical strike chance of your Backstab ability by 30%.
Subtlety Talents (22 points)
Master of Deception - 5/5 points
Reduces the chance enemies have to detect you while in Stealth mode. More effective than Master of Deception (Rank 4)
Opportunity - 5/5 points
Increases the damage dealt when striking from behind with your Backstab, Garrote, or Ambush abilities by 20%.
Improved Ambush - 3/3 points
Increases the critical strike chance of your Ambush ability by 40%.
Initiative - 5/5 points
Gives you a 75% chance to add an additional combo point to your target when using your Ambush, Garrote, or Cheap Shot ability.
Improved Sap - 3/3 points
Adds a 90% chance to return to stealth mode after using your Sap ability.
Preparation - 1/1 points
When activated, this ability immediately finishes the cooldown on your other Rogue
Men vis du ikke bruker ambush , backstab og bare sinister strike, så er det bedre å bruke sverd eller mace , slow som mulig i main hand og raskt så mulig i offhand.
Du er dagger rogue men har ikke imp Ambush eller imp Backstab?
Selv ville jeg aldri ha gått så langt i combat treet om jeg ikke var sword rogue, Adrenaline Rush funker best med Sinister Strike IMO for du kan bare spamme i vei mens med Backstab må du stå bak fienden og det er ikke alltid like lett å spamme Backstabs.
Selv kjører jeg en 30/8/15 build, jeg elsker seal fate for jeg får vanligvis 5 CP etter 3 backstabs (53% crit på backstab). Og Cold Blood er også gode greier.
Imo, beste rogue builden (uten at jeg gidder å gå i detaljer på hver eneste skill, dette er de viktigste):
Viktigste:
Preperation
Improved Sap
Cold Blood
Andre nyttige:
Imp gouge, MoD, Camo, Malice, Ruthlessness, Relentless Strikes,
Og mye mere, husker ikke alle akkurat nå, men det er vel de viktigste.
