Port triggering/Port forwarding
Hei!
Jeg har et problem her.
prøver å spille microsoft spillet allegiance, MEN har selfølgelig problemer...
har sprunget litt fram og tilbake på forumet til spillet, å prøvd å finne ut hvordan jeg løser dette problemet.
tingen er at spillet krever at jeg åpner diverse porter.
her har dere et utdrag fra forumet der.
Allegiance needs ports 2300-2400 to be open on both TCP and UDP protocols. Port 47624 (TCP) is used only to start the connection. If these ports are blocked, you will get the "Cannot Connect to Lobby" error message when trying to log in.
There are two methods to ensure these ports are open for Allegiance: Port Triggering and Port Forwarding. Different devices support different methods, and some better than others. Some devices work well only with forwarding, while others work well only with triggering. You will have to experiment to find the method that works best with your device.
Port Forwarding is a method to tell your device to *always* send ports 2300-2400 to your computer, and your computer alone. With Port Forwarding, those ports are always opened, and are always directed at your computer only. Because of this, a slight security concern exists since the ports are open even when you are not using them. In addition, other users connected to your device are unable to use these ports since they are sent to your computer, and your computer alone. Even though it's less secure and more restrictive (in terms of other computers), it is the most reliable way to configure your device since you are guaranteed that the ports will be forwarded.
Port Triggering is a method to tell your device to keep all ports closed until you need them. The device will listen for a certain "trigger" port to be opened, and when that happens, it will automatically open the other necessary ports, and forward them to the computer that opened the "trigger" port. When the "trigger" port is closed, all other opened ports are closed with it. Because of this, it is more secure since the ports are only open while you are using them. In addition, it is compatible with all computers connected to the device since the ports are forwarded to the computer that opened the trigger port, and not always to the same computer. The drawback is, some devices don't support triggering well, and sometimes it can cause headaches. It's definately the better method to choose if your device can do it. Allegiance is a perfect candidate for Port Triggering since it opens port 47624 (TCP) when you try to play. You can set up a triggering rule to listen for that trigger port, and when heard, it can open ports 2300-2400 (TCP and UDP).
Håper noen kan hjelpe meg til å få åpnet de portene.
har en thompson 510i router å nextgentel bredbånd.
takk på forhånd
Du må sannsynligvis portforwarde din router for å få løst dette problemet, og hvis du orker å gjøre denne jobben selv så finner du mer info om dette på denne linken om Portforwarding av router (her finner du alle typer router og hvordan)
Portforward
Om du sitter alene bak ruteren så er nok det enkleste å se om den har DMZ. DMZ eller demilitarized zone som det heter på nynorsk, gjør at all trafikk blir videresendt til IP'en du spesifiserer. Dette gjør at du ikke trenger å port forwarde (du er riktignok mer sårbar mot "angrep," så brannmur er en nødvendighet).
