DC Final er sluppet!
Finnes kun Desert Combat 0.8 på www.fileplanet.com utenom bittorrent siden?
Og er det kun en patch fra 0.7 versjonen?
Foreløpig er det bare en patch. Søk på DC Final @ google.com så finner du fort ut hvor du kan laste ned.
Laster den ned aws fra fileplanet... lurte i grunnen bare på hvorfor den bare var lagt ut på én major site
EDIT: Har battlefield.no sin DC server oppgradert til 0.8?
De oppgradere sikkert i ettermidag.. bare følg med på battlefield.no
Serveren vår er selvsagt oppdatert, så du kan spille DC Final her:
Battlefield.no Desert Combat Final: alexandra.battlefield.no:14567
Kartlista inneholder kun nye kart som er rene DC-kart (altså ikke konverterte BF 1942-klassikere):
dc_al_nas, dc_bridge, dc_coastal_hammer, dc_cornered, dc_dustbowl, dc_al_nas_day_2, dc_firstlight, dc_twin_rivers
Endret av SpinNdre
Hva er nytt med den nye patchen?
List det opp...  ;)
Les i vei:
-----DC Final Changelist-----
DC_Final Client Full, version 3
-Removed remaining horn and artillery spot icons
-Adjusted patriot rotation
-Spandrel rotation slowed but has a strange bug meaning it still moves fast for short adjustments
-Reduced MI24 gunner overheat, very light now
-SA-342 gunpods reduced overheat some more
-Launch effects added to all aircraft missiles
-Moved F117 bombs down slightly
-New missile smoke for aircraft
-Fixed Ural fueldrums damaging truck, can still walk through fueldums while on truck but it's now harder to get in
-Gaskin missile same as Linebacker
-Enterprise UH-60q spawn corrected for vertical takeoff
-Sparks added to metal collisions
-humvee/car explosions cause some screen shake when close to explosion
-adjusted many weapon icons in vehicles, most were still using the same BF rocket icon
-fixed bug with turret sounds
-adjusted linebacker rotation
-fixed F16 bug with some linux servers
-Gaskin lights fixed
-Gaskin turret icon removed
-F117 given f14 minimap icon
-US sniper kit has removed backpack
-Iraqi sniper helmet readded
-Patriot HP increased to match SA3
-created unexplainable, unfixable catastrophic crashing bug
-had dinner and fixed catastrophic crashing bug
-changed linebacker launch sounds
-removed patriot wreck
-random iraqi skin removed
-reduced time to live for F117 bomb down to 5 seconds, will airburst if it hasn't hit the ground. Needs some testing.
-reduced radius of F117 bomb by 20%
-increased camera stay for patriot/sa3 to 3 seconds
-patriot missile detonate changed to altfire to avoid launching second missile on detonation
-Reworked AK/AKS sounds
-Reworked Shilka third person sound
-Better explosion effects in Weapon Bunkers
-Fixed serveral projectile positions
-Removed horn icons
-Reduced muzzle smoke on some weapons
-Optimised tank explosions
-Pantsyr icon fixed
-BMP1 health and ammo added
-Iraqi AT3 kit fixed
DC_Final Client Full, version 2
-Removed horn icons
-Second iraqi skin randomly chosen
-Collision of barrels on fueldrum ural fixed
-Pantsyr icon fixed
DC_Final Client Full, version 1
-Mortar given overheat on deployment, can't drop another for about 30 seconds. The overheat per shot is 150%
and it accumulates so if you deploy one when the overheat bar is at half way it gets pushed up to 200%.
-New M1A1 reload sound
-AI added to binoculars, bots will target heavy armor when very close
-Smoke grenade effect made larger
-Blood effect added to knife stabs
-Running footsteps can be heard further away
-Reload bar added to hind FFARs
DC_Final RC3
-All TOW Missiles now shoot straight
-M82 given large muzzle flash light effect
-Skorpion ROF slightly higher
-Saiga given larger muzzle lift per shot
-MK23 ROF upped to match other pistols
-SA-342 gunpod overheat reduced
-SA-3/Patriot range increased
-SA-3/Patriot smoke effect changed
-SA-7s in SA-7 boxes
-All in-vehicle radios placed in their own sound file (Can be renamed or removed to improve performance)
-Artillery muzzle smoke slightly reduced
-Massive reduction in sound.rfa size
-Stinger's Humvee textures
-Adjusted SCUD driver camera position
-New sounds for ammo reload, reloading vehicles now different sound to soldiers
-Wrench can be heard from several meters away and has new sound
-AA classes given MP5 and Skorpion
-Stryker driver's head fixed
DC_Final RC2
-Overheats fixed
MH500 overheat
Technical overheat
DPV overheat
SA342 overheat
-Mortar wall hack fixed
-New Scoreboard icon for Spec Ops
DC_Final RC1
-Both LCAC versions should be fixed
-Mortar view adjusted
-Mortar explosions more deadly but with less force (bodies don't get thrown so far)
-US player model has new shader parameters, fixed 1st person camo.
-US and Iraqi player models have more variety in 'accessories'
-Fixed issue with Spandrel turret
-New fake crater effect for scud explosions. Large stone pieces are blown off buildings
that get hit.
-Modified most smoke trails and missile flames
-New sounds for:
Missile launchers on helicopters
Car-15
NVST
TOW launch
-Reduced volume of birds
-Many small fixes to incorrect crosshairs
-Fixed missing MLRS kickback
-New minimap icons for virtually all the different vehicles
-Fixed Stryker drivers head showing
-Changed Tomahawk explosion effect
-Increased audible range of choppers for medium and high sound settings
-Slowed MI24d gunners rotation speed
0.8f
-Shilka materials and health revised, splash vs. infantry removed. - It now takes 2 RPGs to kill (down from 4),
2 tank shells (up from 1), isn’t particularly vulnerable to 20mm Fighter cannons (used to be), 2 Spandrel rockets
(up from 1), 35 30mm shells (BMP2, m2a3), 1 artillery shell, 1 c4 stick (down from several). Should still be exactly
as potent vs. aircraft.
-Vulcan splash vs. infantry removed, death explosion reduced
-Stinger damage vs. Hind, Apache, Blackhawk reduced
-Larger helicopters maneuverability improved
-SU25 cannon splash set to match A10's
-M1A1/T72 maximum turret angle reduced 2 degrees
-M2A3/BMP2 round velocity increased
-Humvee and DPV strengthened to reduce terrain damage
-Most wheeled vehicles handling modified
-BDRM health upped 50% to 75, death explosion reduced.
0.8e
-Added Howitzer and Howitzer battery
-Added Patriot
-Added LCAC
-Reflective US goggles
-MI8 handling improved
-Armed MI8 without spawn points added
-Radios added to most aircraft
-Radios added to Humvees
-New cockpit sounds for some aircraft
-Many silent gun positions given rotation and reload sounds
-Pantsyr front passenger added, radar fixed
-Spandrel and Gaskin turrets slowed slightly
-All Brownings and NVSTs now have improved gun camera position
-New sounds for:
Stinger and SA-7
M25
Bullet cases
Mortar and mine deploy
-New M25 model and skin
-Freelook added to all chopper passengers
-Slightly reduced speed of freelook in aircraft
-Changed explosion effects for most airburst missiles
-Cockpit and zoom added to AH64 gunner
-Zoom added to Hind gunner
-F14b bomb position gets crosshair
-Fixed ZPU muzzle flash position
-Skorpion deviation reduced
-New theme music courtesy of Andre Hofmann
-Added dust effect to some chopper wheels to simulate rotor wash
-Removed unused artillery icon from UH-60
0.8d
-New PKM, M249 and Remington animations
-Remington pump sound added
-AK47 reload animation plays slightly faster
-Reduced fall damage
-All vehicles now have gunner position as position 2
-New stationary PKMs with crouching shooters
-Horns added to several vehicles
-VSS does less damage over long distance
-Added BMP1
-Updated MP5 model
-Most voices reworked
-Standard Ural has 3 extra passengers in the back, 2 facing inwards the last sitting on the back of the tray.
-Fueldrum Ural that drops explosive barrels controlled by the driver
-Recoilless rifle Ural, mounted in the tray
-AA Ural with top half of a ZPU, ammo boxes and sandbags sitting on the tray area
-Added MK-19 Humvee
-Added Minigun Humvee
-More new effects for vehicle damages and explosions
0.8c
-Fixed Humvee resupply spots
-New ammo boxes
-Adjusted zoom angle for MP5 and AKS
-Fixed recoil animation bug with pistols, sniper rifles and Remington
-Larger blast radius for mortar
-Reduced screen shake for explosions
-Reduced excessive screen shake firing sniper rifles standing
-Many muzzle flash fixes and improvements
-Rear wheels now roll on AH-64, UH-60s, MI-24, MH-53 and MI-8
-Screen shake added to ZPU
-Camera stay time on guided sa-3 reduced to 2 seconds
-New explosions for mines and C4
-Added F-117 armed with GBU-27 bomb. Same power as scud.
-Added Gaskin AA variant of BRDM
-Guided SA-3 missiles explode when out of fuel, launch effect and screen shake added
-Moved BRDM supply depot away from driver
0.8b
-SMAW/RPG blast radius slightly higher
-MK19 has doubled rate of fire, damage unchanged
-Rate of fire changed for shotguns
-VSS slightly reduced power
-New Humvee handling code
-Fixed the massive blast radius of the MGs and RHIB
-1 stab kills with knife
-Reduced spiral on Hydras
-New US player model
-New M9 model
-Many new explosion effects
-New bullet impacts
-Many new sounds for weapons and vehicles
-Removed bullet whiz sounds for shotguns
-Modified muzzle flashes for many weapons
-New smoke trails
-Icons added for all useable objects in vehicles
-Modified screen shakes for weapons
-New Environment sounds added to most maps
0.8a
-Artillery velocity reduction for improved arc
-Sniper rifles fire faster.
-MBTs with more momentum to the turrets, longer reload time, more powerful shell.
-MLRS and BM21 turret speed given momentum like the M109
-Created proper Iraqi SA-7 armory
-new soundscript for mortar in flight
-Renewed special impact effects for heavy calibers
-Mk19 given higher rate of fire with smaller clip and more spread
-New SA-3 system with joystick control made from Tan mod
Endret av SpinNdre
ØØØØ! Hadde 5 min igjen av download, så crasha internet explorer pga dama var på ei møkka-forumside... lasta ned med downloadmanagr fra fileplanet... går det an å starte der jeg var? I så fall hvordan
Er ferdig å laste ned men får desverre ikke testet før senere i dag, fordi jeg skal bort til en kamerat og hente DC 0.7 Installasjonen. I kveld skal det spilles :cool:
Opera :whistle:
Opera :whistle:
STFU!!! :p
EDIT: IE klikker aldri for meg men det møkka-forumet dama er på får IE til å klikke hele tiden!! :mad::hrm::thumbdown:
Endret av Odland81
Opera :whistle:
STFU!!! :p
Allikevell er Opera en mye bedre nettleser og du kan forstette der du slapp hvis det klikker! :roll:
edit: Den klikket jo tydeligvis for deg :p
Endret av SpinNdre
Sant nok at Opera er bedre, men jeg har ikke hatt problemer med IE etter SP2 så jeg har liksom ikke giddet å bytte... men en ting er sikkert: Dama skal ikke få henge på det forumet når jeg laster ned ting, thats for sure :yes:
EDIT: Noen flere som ikke synes den DC Final var verdt ventetiden? Inne på serverene whiner jo alle som besatt.
Endret av Odland81
Jeg. Det har jo vert snakk om dene realesen lenge men det var ikke noe "OMG!! Så kult!!". Som feks Forgotten Hope som kom som en bombe på meg.
edit: at installasjonen ikke funka hjalp ikke akkuratt
Endret av SpinNdre
Jeg. Det har jo vert snakk om dene realesen lenge men det var ikke noe "OMG!! Så kult!!". Som feks Forgotten Hope så kom ned fra himmelen.
Den er helt grei, men ikke noe mer... synd at en del har lagg-problemer med den... jeg fikk en del høyere ping enn vanlig... slik at alle stjal helekopterene rett foran nesa på meg... irriterende... stod å vente på chopper så kom det en 5-6 stykker og snachet dem... :mad:
Bad for you :p
Men for all del, DCF er en av de aller beste BF1942 modene som er laget. :thumbup:
At dere har lag er jo serverene sin feil - nå når modden er ny setter folk desperat opp server for å prøve ut, og dessverre fører det til at en del BS-servere er tilgjengelig... Etterhvert som modden blir noen dager/uker gammel faller de elendige serverene bort fordi folk ikke orker å spille i lag-helvette, og de stødige serverene som kjører uten problemer står igjen...
Slik er det etter ALLE mods og patch-releaser, så jeg synes det vil være litt tidlig å snakke om at MODden skaper lag på serverene...
Endret av Croyfer
Hva synst du om spillet da? ;)
Den blir kulere og kulere, er en bane som er sweet, men VM i baserape... husker ikke helt hva den heter... men den "faste" basen er over en bro, og på andre siden av broen er det en lastebil man kan "spawne" i.
Er det noen av de nye mapsene som har bot support?
Skulle gjerne likt å spille på nett, men akkurat nå sitter (den forbanna) broren min og laster ned alt mulig dritt, slik at jeg får mellom 500 og 1500 ping :thumbdown:
