Koder til The Sims 2?
tast crtl + shift + c for å få opp console.
"help -all" viser en del koder.
"motherlode" gir deg masse penger!
"kaching" gir deg 1000... (usikker på denne)
Er det noen som vet pengekoden til Sims 2?
å herregud da!
Spillet har knapt kommet ut, og likevel spør folk etter cheats...
Du har vel sikkert ikke tenkt å PRØVE å spille spillet uten koder, du? :roll:
jeg kan ikke si jeg tar the sims 2 som noe spesielt seriøst spill å "runne".
jeg bare spiller det for å ha det morro, altså max med cash med engang...
skriv "motherload" i konsollen ...
Endret av Keylar
Her er en oversikt over de fleste kodene:
Cheat mode:
Press [Ctrl] + [shift] + C during game play to display the console window. Enter one of the following codes to activate the corresponding cheat function. Note: Some codes may be case-sensitive.
Effect Code
List most cheat codes help
Display information about indicated cheat help <cheat command>
Close console window exit
Expand or contract console window expand
1,000 more Simoleons Kaching
50,000 more Simoleons motherlode
Remove all Sims; use in neighborhood view deleteAllCharacters
Toggle terrain types; use in neighborhood view TerrainType <desert or temperate>
Objects can be placed anywhere in buy and build modes; hand tool can move any object moveObjects <on or off>
Make Sims larger or smaller StretchSkeleton
Prevent Sims from aging aging <on or off>
Toggle automatic game updates autoPatch <on or off>
Slow motion; 0 is normal, 8 is slowest slowMotion <0-8>
Increase game performance with some graphics glitches Vsync <on or off>
Enable postprocessing cheats; requires video card that supports pixel shaders boolProp enablePostProcessing <true or false>
Information in this section was contributed by Kevin, CyberBob, and Devon.
Postprocessing cheats:
Use the following case-sensitive codes after enabling the Postprocessing cheats with the boolProp enablePostProcessing true code. Note: Do not enable or use the Postprocessing cheats unless your video card supports pixel shaders.
Effect Code
Blur effect; red, green, blue value must be between 0 and 255, and x (bloom) between 0.0 and 1.0 bloom <r g b x>
Centered blur effect; centerX and centerY are screen coordinates; x (vignette) must be between 0.0 and 1.0 vignette <centerX centerY x>
Grainy screen effect filmGrain <0.0-1.0>
Letterbox screen effect letterBox <0.0-0.4>
Information in this section was contributed by Devon.
Tok 1/2 min å finne på www.gamewinners.com
  • 3 år senere...
Motherlode 50.000
Også FamilyFunds (eeternavnet til familien) (beløpet familien skal få)
feks. FamilyFunds Andersen 500000
vips så får familien 500.000
flere koder gå inn på christinakokoz.piczo.com\cheat :thumbup:
Gjest
