Diskwiper software?
MrLee
Hei, skal selge PC, så jeg er på utkikk etter ett program til å wipe disken min helt sånn at det ikke er mulig for kjøper å gjennopprette filer (ja jeg veit at det alltid er litt mulighet for det, men ingen vits i å gjøre det enkelt heller? ;) )
helst Freeware eller shareware (som funker, og ikke bare er demo av GUI lissom)
jeg vil ha det software som barneporno folka ønska de hadde før politiet kom på døra :p
jepp jeg prøvde xenzor, men det meste var sånn som var demo eller bare wipa temp filer, og spor på hva du har surfa på nettet og sånnt..
spanx wayshot! :)
Jeg sier bare killdisk .
Active@ KillDisk FREE version features:
Detects and displays information about all partitions, hard disks and floppy drives currently connected to your computer
Wipes out all floppies and hard disk drives completely by secure overwriting data on physical level using [One Pass Zeros] data destruction method
Erases partitions, logical drives and even not used disk space
Erasing report is created and can be saved as a file
Supports IDE and SCSI drives
Supports larger than 8GB hard disks via using LBA mode to access drive's data
File systems (FAT, FAT32, NTFS, etc) on the drive do not matter, detected physical drive is erased using low-level disk access
Double confirmation excludes possibility of accidental erasing of data on a drive
Very easy to use, utility has intuitive console interface and command line mode for the advanced users
Works on any system capable of boot from floppy in DOS mode
Utility is so compact that can be placed on bootable diskette and used from it. You do not even need to boot from the hard drive to destroy it
Cleans hard drive, floppies, etc.
FREE product updates from the Web
Active@ KillDisk Professional version additional features:
All above-mentioned
US Department of Defense Data Security Standard DoD 5220.22 M compliant
Supports several erasing methods including the most secure Gutmann's algorithm
Data verification could be performed after erasing is completed
