Problem med å starte enemy territory
Har akkurat installert Enemy Territory 2.60, men når jeg skal gå inn i spillet kommer denne feil: "GLW_StartOpenGL() - could not load OpenGL subsystem".
Noen som kan hjelpe meg?
Her er hele teksten som står i en boks som kommer opp:
ET 2.60b win-x86 May 8 2006
----- FS_Startup -----
Current search path:
C:\Programfiler\Wolfenstein - Enemy Territory\etmain\pak2.pk3 (22 files)
C:\Programfiler\Wolfenstein - Enemy Territory\etmain\pak1.pk3 (10 files)
C:\Programfiler\Wolfenstein - Enemy Territory\etmain\pak0.pk3 (3725 files)
C:\Programfiler\Wolfenstein - Enemy Territory\etmain\mp_bin.pk3 (6 files)
C:\Programfiler\Wolfenstein - Enemy Territory/etmain
3763 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
  • 4 måneder senere...
