Stuck i Halflife 2
Jeg har kommet til den store bygningen foran "city 17" der du skal ødelegge 3 generatorer. Jeg har tatt 2 av dem og mangler da den siste. Problemet er at i et av rommene, er det masse små røde lasere, når jeg kommer borti de dukker opp noen turrets i taket som skyter meg til jeg dauer, hva skal jeg gjøre der?
12.7: Right path wha?
- This is right from the generator room, Turrets facing you. This should
lead you to a corridor with three exits: one is a dead end with a turret,
one is a entrance to the generator room, and the third is a exit to the
main stairwell from the beginning of the level part. Take the middle. You
should see a room laden with red lines. Jump on the above plank and walk
past the red lines. Next, jump on the plank and jump over the red lines.
Now, walk around the path and crawl under the red planks. Bear in mind,
hoppers will be everywhere. After crawling under, climb the plank with
the red lines, but don't run into them. Then, jump to the pipes and walk
over them and drop down. Turn the red beams off. Provided your rag
tag group survived the combine guards attacking outside, (Barney will if
you're quick), they will now enter the room. Enter the Generator room and
disable it. A blue line should be before it and have two turrets ready.
Kill them.
12.8: Left path wha?
- This is left from the generator room, Turrets facing you. You
should find a room with an open door, two inactivated hoppers, and an
open exit. Enter this room and try to exit. It's a trap. The doors close
and combine fire at you through the holes in the wall. Fight em off best
you can. After they get bored, they will open the doors. The first door is
where you should use your hoppers as traps. Two elites and 5 Combine storm
it. The other one is easy enough. Three combine. Exit, find the generator
room, and disable it. Now try to go back downstairs toward that first
force field you saw as you entered the suppressor building. The one where
the first three combine attack.
neinei jeg gjorde litt feil da skjønner dere :p sneik meg fram til dit det var giejn 2 stråler, men skjønte ikke hvordan jeg skulle komme meg over de, så jeg gjennom dem og bort til knappen. Men da var det jo ikke rart det ikke skjedde noe :p
